This class encapsulates the information and simple method for key events interative actions.
KeyEventInteractionArguments(String,Boolean,Boolean,Boolean)
IsShiftKeyPressed
* Gets a value indicating whether the SHIFT key was pressed. true if the SHIFT key was pressed; otherwise, false.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#IsShiftKeyPressed//
CurrentExtent
* This property gets or sets the current extent used in the MapControl.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#CurrentExtent//
ZoomLevelSnapping
* This property gets or sets the ZoomLevelSnappingMode used in the Map Control.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#ZoomLevelSnapping//
