thinkgeo.mapsuite.desktopedition.mapmousemoveinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.MapMouseMoveInteractiveOverlayEventArgs
Provides data for the MapMouseMove event.
      • ThinkGeo.MapSuite.DesktopEdition.MapMouseMoveInteractiveOverlayEventArgs
MapMouseMoveInteractiveOverlayEventArgs()
  • If you use this constructor, you must set the properties manually before use.
MapMouseMoveInteractiveOverlayEventArgs(InteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseMoveInteractiveOverlayEventArgs#MapMouseMoveInteractiveOverlayEventArgs.28InteractionArguments.29
  • interactionArguments
    • Description:This parameter specifies the interaction arguments used to construct the class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseMoveInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseMoveInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseMoveInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseMoveInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseMoveInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseMoveInteractiveOverlayEventArgs#MemberwiseClone.28.29
  • This property gets the interaction arguments for the mouse click event args.
thinkgeo.mapsuite.desktopedition.mapmousemoveinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
