thinkgeo.mapsuite.desktopedition.mapmousewheelinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.MapMouseWheelInteractiveOverlayEventArgs
Provides data for the MapMouseWheel event.
      • ThinkGeo.MapSuite.DesktopEdition.MapMouseWheelInteractiveOverlayEventArgs
MapMouseWheelInteractiveOverlayEventArgs()
  • If you use this constructor, you must set the properties manually before use.
MapMouseWheelInteractiveOverlayEventArgs(InteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseWheelInteractiveOverlayEventArgs#MapMouseWheelInteractiveOverlayEventArgs.28InteractionArguments.29
  • interactionArguments
    • Description:This parameter specifies the interaction arguments to construct the class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseWheelInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseWheelInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseWheelInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseWheelInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseWheelInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseWheelInteractiveOverlayEventArgs#MemberwiseClone.28.29
  • This property gets the interaction arguments for the event args.
thinkgeo.mapsuite.desktopedition.mapmousewheelinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
