thinkgeo.mapsuite.desktopedition.interactiveresult
ThinkGeo.MapSuite.DesktopEdition.InteractiveResult
This class specifies the InterativeResult when dealing with the Interative method in InterativeOverlay.
    • ThinkGeo.MapSuite.DesktopEdition.InteractiveResult
InteractiveResult()
  • If you use this constructor, you must set the properties manually before use.
InteractiveResult(InteractiveOverlayDrawType,ProcessOtherOverlaysMode)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#InteractiveResult.28InteractiveOverlayDrawType.2C_ProcessOtherOverlaysMode.29
  • interactiveOverlayDrawType
    • Description:This parameter specifies the interactiveOverlayDrawType used to construct the class.
  • processOtherOverlays
    • Description:This parameter specifies the processOtherOverlays used to construct the class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#MemberwiseClone.28.29
DrawThisOverlay
  • This property gets and sets the DrawThisOverlay type, which indicates whether to draw this overlay or not.
NewCurrentExtent
  • This property gets and sets the new current extent if the interative action affects the extent.
thinkgeo.mapsuite.desktopedition.interactiveresult.txt · Last modified: 2017/03/16 21:59 (external edit)
