thinkgeo.mapsuite.desktopedition.processotheroverlaysmode
ThinkGeo.MapSuite.DesktopEdition.ProcessOtherOverlaysMode
  • This enumeration specifies the mode used to process other overlays when doing interactive actions with InterativeOverlay.
  • For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ProcessOtherOverlaysMode// == Items == ProcessOtherOverlays * Summary:This enumeration item means that other overlays will still be executed. DoNotProcessOtherOverlays * Summary:This enumeration item means that other overlays will be ignored. Default * Summary:Default value of the enumation, the same as ProcessOtherOverlays.
thinkgeo.mapsuite.desktopedition.processotheroverlaysmode.txt · Last modified: 2017/03/16 21:59 (external edit)
