thinkgeo.mapsuite.desktopedition.extentinteractiveoverlay
ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay
This class inherits from the interactiveOverlay abstract class. This specified overlay describes the Extent Changing interactive process with the MapControl using the Mouse or Keyboard.
    • ThinkGeo.MapSuite.DesktopEdition.Overlay
      • ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlay
        • ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay
ExtentInteractiveOverlay()
  • Default constructor of the class. If you use this constructor, please set the properties correctly or it will use their default values.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#ExtentInteractiveOverlay.28.29
KeyDown(KeyEventInteractionArguments)
  • This method will simulate the KeyDown interaction.
  • This method is the concrete wrapper for its virtual Core method. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
KeyUp(KeyEventInteractionArguments)
  • This method will simulate the KeyUp interaction.
MouseDown(InteractionArguments)
  • This method will simulate the MouseDown interaction.
  • interactionArguments
    • Description:This parameter represents the interaction auguments for the method.
MouseMove(InteractionArguments)
  • This method will simulate the MouseMove interaction.
MouseUp(InteractionArguments)
  • This method will simulate the MouseUp interaction.
MouseClick(InteractionArguments)
  • This method will simulate the MouseClick interaction.
MouseDoubleClick(InteractionArguments)
  • This method will simulate the MouseDoubleClick interaction.
MouseWheel(InteractionArguments)
  • This method will simulate the MouseWheel interaction.
Refresh(GeoCanvas,RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#Refresh.28GeoCanvas.2C_RectangleShape.29
DrawPreview(GeoCanvas)
  • This method will be used to draw preview tiles to the canvas.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#DrawPreview.28GeoCanvas.29
  • Description:The tile existing type, which indicates whether any tiles exist.
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object to draw on.
Draw(GeoCanvas)
  • This method draws the Overlay.
  • This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the overlay based on the extent you provided. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • canvas
    • Type:GeoCanvas
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#GetType.28.29
MouseDownCore(InteractionArguments)
  • This overrides the MouseDown logic in its base class interactiveOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#MouseDownCore.28InteractionArguments.29
MouseMoveCore(InteractionArguments)
  • This overrides the MouseMove logic in its base class interactiveOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#MouseMoveCore.28InteractionArguments.29
MouseUpCore(InteractionArguments)
  • This overrides the MouseUp logic in its base class interactiveOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#MouseUpCore.28InteractionArguments.29
MouseClickCore(InteractionArguments)
  • This overrides the MouseClick logic in its base class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#MouseClickCore.28InteractionArguments.29
MouseDoubleClickCore(InteractionArguments)
  • This overrides the MouseDoubleClick logic in its base class interactiveOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#MouseDoubleClickCore.28InteractionArguments.29
MouseWheelCore(InteractionArguments)
  • This overrides the MouseWheel logic in its base class interactiveOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#MouseWheelCore.28InteractionArguments.29
DrawCore(GeoCanvas)
  • This method draws the ExtentInteractiveOverlay.
  • This method draws the representation of the overlay based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object or a GeoImage to draw on.
KeyDownCore(KeyEventInteractionArguments)
  • This protected virtual method is the Core method of KeyDown API.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#KeyDownCore.28KeyEventInteractionArguments.29
KeyUpCore(KeyEventInteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#KeyUpCore.28KeyEventInteractionArguments.29
OnMapMouseDown(MapMouseDownInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseDown is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#OnMapMouseDown.28MapMouseDownInteractiveOverlayEventArgs.29
OnMapMouseMove(MapMouseMoveInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseMove is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#OnMapMouseMove.28MapMouseMoveInteractiveOverlayEventArgs.29
OnMapMouseUp(MapMouseUpInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseUp is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#OnMapMouseUp.28MapMouseUpInteractiveOverlayEventArgs.29
OnMapMouseClick(MapMouseClickInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseClick is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#OnMapMouseClick.28MapMouseClickInteractiveOverlayEventArgs.29
OnMapMouseDoubleClick(MapMouseDoubleClickInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseDoubleClick is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#OnMapMouseDoubleClick.28MapMouseDoubleClickInteractiveOverlayEventArgs.29
OnMapMouseWheel(MapMouseWheelInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseWheel is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#OnMapMouseWheel.28MapMouseWheelInteractiveOverlayEventArgs.29
OnMapKeyDown(MapKeyDownInteractiveOverlayEventArgs)
  • This event will be fired when MapKeyDown is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#OnMapKeyDown.28MapKeyDownInteractiveOverlayEventArgs.29
OnMapKeyUp(MapKeyUpInteractiveOverlayEventArgs)
  • This event will be fired when MapKeyUp is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#OnMapKeyUp.28MapKeyUpInteractiveOverlayEventArgs.29
OnDrawing(DrawingOverlayEventArgs)
  • This event will be fired before Overlay is drawn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#OnDrawing.28DrawingOverlayEventArgs.29
OnDrawn(DrawnOverlayEventArgs)
  • This event will be fired after Overlay is drawn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#OnDrawn.28DrawnOverlayEventArgs.29
RefreshCore(GeoCanvas,RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#RefreshCore.28GeoCanvas.2C_RectangleShape.29
DrawPreviewCore(GeoCanvas)
  • This is the core method of DrawPreview which is intended to be overridden by its concrete sub class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#DrawPreviewCore.28GeoCanvas.29
  • canvas
    • Type:GeoCanvas
sBM=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#DrawAttributionCore.28GeoCanvas.29
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29
  • This method will draw on the canvas when an exception occurs during the drawing process.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#DrawException.28GeoCanvas.2C_Exception.29
  • canvas
    • Type:GeoCanvas
  • e
    • Type:Exception
    • Description:This parameter is the exception that is occurring.
  • This method is the Core method of DrawException, which can be overridden if you want to change its logic. This method will draw on the canvas when an exception occurs during drawing process.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#DrawExceptionCore.28GeoCanvas.2C_Exception.29
  • canvas
    • Type:GeoCanvas
  • e
    • Type:Exception
OnRequestedDrawing(RequestedDrawingOverlayEventArgs)
OnRequestingDrawing(RequestingDrawingOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay#MemberwiseClone.28.29
IsEmpty
  • This property overrides its property in the base class by watching the feature count in trackZoomLayer. If it is empty, we can skip drawing it for better performance.
PanMode
  • This property gets or sets the PanMode used for the ExtentInteractiveOverlay.
DoubleRightClickMode
  • This property gets or sets the DoubleRightClickMode used for the ExtentInteractiveOverlay.
LeftClickDragMode
  • This property gets or sets the LeftClickDragMode used for the ExtentInteractiveOverlay.
LeftClickDragKey
  • This property gets or sets the Keys used in LeftClickDrag for the ExtentInteractiveOverlay.
  • Type:Keys
ExtentChangedType
  • This property gets or sets the ExtentChangedType for the ExtentInteractiveOverlay.
Lock
  • This property gets the OverlayLock object.
DrawingExceptionMode
  • This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
  • Gets or sets the name of the overlay, which can be used to represent a specific overlay.
DrawingTime
  • This property gets the last drawing time for the Overlay.
  • We track the drawing time for the Overlay and report it back in this method. This is useful to determine the speed of various Overlays.
  • Type:TimeSpan
AutoRefreshInterval
  • Type:TimeSpan
PanAndTrackZoomState
  • This protected property gets and sets the PanAndTrackZoomState with the information stored.
xRM=
rxM=
MapMouseDown
  • This event will be fired when the Mouse button is pressed (down) on the Map.
Event Arguments:MapMouseMoveInteractiveOverlayEventArgs
MapMouseUp
  • This event will be fired when the Mouse button is released (up) on the Map.
Event Arguments:MapMouseClickInteractiveOverlayEventArgs
MapMouseDoubleClick
  • This event will be fired when the Mouse button is double-clicked on the Map.
Event Arguments:MapMouseWheelInteractiveOverlayEventArgs
MapKeyDown
  • This event will be fired when the key is pressed down when focusing on the Map.
Event Arguments:MapKeyUpInteractiveOverlayEventArgs
Drawing
  • This event will be fired before the Overlay is drawn.
Event Arguments:DrawnOverlayEventArgs
DrawingAttribution
Event Arguments:RequestedDrawingOverlayEventArgs
RequestingDrawing
Event Arguments:RequestingDrawingOverlayEventArgs
thinkgeo.mapsuite.desktopedition.extentinteractiveoverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
