thinkgeo.mapsuite.desktopedition.mapdoublerightclickmode
ThinkGeo.MapSuite.DesktopEdition.MapDoubleRightClickMode
  • This enumeration specifies the behavior that occurs when double-right-clicking on the MapControl. The default value is ZoomOut.
  • For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapDoubleRightClickMode// == Items == Default * Summary:Default value (ZoomOut) of the enumeration. ZoomOut * Summary:This enumeration item means that the map will ZoomOut when a double-right-click occurs. Disabled * Summary:This enumeration item means that the ZoomOut functionality for double-right-clicks will be disabled.
thinkgeo.mapsuite.desktopedition.mapdoublerightclickmode.txt · Last modified: 2017/03/16 21:59 (external edit)
