thinkgeo.mapsuite.desktopedition.mapdoubleleftclickmode
ThinkGeo.MapSuite.DesktopEdition.MapDoubleLeftClickMode
  • This enumeration specifies the behavior that occurs when double-left-clicking on the MapControl. The default value is ZoomIn.
  • For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapDoubleLeftClickMode// == Items == Default * Summary:Default value (ZoomIn) of the enumeration. ZoomIn * Summary:This enumeration item means that the map will ZoomIn when a double-left-click occurs. Disabled * Summary:This enumeration item means that the ZoomIn functionality for double-left-clicks will be disabled.
thinkgeo.mapsuite.desktopedition.mapdoubleleftclickmode.txt · Last modified: 2017/03/16 21:59 (external edit)
