thinkgeo.mapsuite.giseditor.dockwindowmanager
ThinkGeo.MapSuite.GisEditor.DockWindowManager
<!– Class –> This class represents a dock window manager.
Public MethodDockWindowManager Initializes a new instance of the class.
Public MethodApplySettings StorableSettings Manager Applies the settings to this manager.
Public MethodGetDockWindowState DockWindow
Public MethodGetSettings Manager Gets manager settings to save.
Public MethodGetSettingsUI Manager Gets an UI that configures settings.
Public MethodGetType Object
Public MethodOpenDockWindow DockWindow, DockWindowPosition Opens the dock window with specific position.
Public MethodOpenDockWindow DockWindow Opens the dock window.
Public MethodSortDockWindows
Public MethodToString Object
Protected MethodApplySettingsCore StorableSettings Manager(overriden) Applies the settings of dock window manager.
Protected MethodGetDockWindowStateCore DockWindow
Protected MethodGetSettingsCore Manager(overriden) Gets the settings of dock window manager to save.
Protected MethodGetSettingsUICore Manager Gets an UI that configures settings.
Protected MethodOnDockWindowOpened DockWindowOpenedDockWindowManagerEventArgs Raises the event.
Protected MethodOnSortedDockWindows IEnumerable<DockWindow>
Protected MethodOnSortingDockWindows
Protected MethodOnThemeChanged ThemeChangedDockWindowManagerEventArgs Raises the event.
Protected MethodOpenDockWindowCore DockWindow, DockWindowPosition Opens the dock window with specific position.
Public PropertyActiveDocumentIndex Int32 Gets or sets the index of the active document.
Public PropertyDockWindows ObservableCollection<DockWindow> Gets all the dock windows.
Public PropertyDocumentWindows ObservableCollection<DocumentWindow> Gets all the document windows.
Public PropertyTheme Theme Gets or sets the theme of dock window.
DockWindowManager()
Name Type Description
Go Back
ApplySettings(StorableSettings)
Return Type Description
Void<!– System.Void –>
settings StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> The settings to be applied to this manager.
<!– ThinkGeo.MapSuite.GisEditor.Manager –> Go Back
Boolean<!– System.Boolean –>
GetDockWindowState(DockWindow)
DockableContentState<!– AvalonDock.DockableContentState –>
dockWindow DockWindow<!– ThinkGeo.MapSuite.GisEditor.DockWindow –>
<!– ThinkGeo.MapSuite.GisEditor.DockWindowManager –> Go Back
Int32<!– System.Int32 –>
GetSettings()
StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> Manager's settings to save
GetSettingsUI()
SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> A SettingUserControl that configures settings.
Type<!– System.Type –>
OpenDockWindow(DockWindow, DockWindowPosition)
dockWindow DockWindow<!– ThinkGeo.MapSuite.GisEditor.DockWindow –> The dock window.
dockWindowPosition DockWindowPosition<!– ThinkGeo.MapSuite.GisEditor.DockWindowPosition –> The dock window position.
OpenDockWindow(DockWindow)
SortDockWindows()
Collection<DockWindow><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.GisEditor.DockWindow} –>
String<!– System.String –>
ApplySettingsCore(StorableSettings)
settings StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> The settings.
<!– ThinkGeo.MapSuite.GisEditor.Manager(overriden) –> Go Back
GetDockWindowStateCore(DockWindow)
GetSettingsCore()
GetSettingsUICore()
OnDockWindowOpened(DockWindowOpenedDockWindowManagerEventArgs)
Raises the event.
e DockWindowOpenedDockWindowManagerEventArgs<!– ThinkGeo.MapSuite.GisEditor.DockWindowOpenedDockWindowManagerEventArgs –> The instance containing the event data.
OnSortedDockWindows(IEnumerable<DockWindow>)
sortingDockWindows IEnumerable<DockWindow><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.GisEditor.DockWindow} –>
OnSortingDockWindows()
OnThemeChanged(ThemeChangedDockWindowManagerEventArgs)
Raises the event.
e ThemeChangedDockWindowManagerEventArgs<!– ThinkGeo.MapSuite.GisEditor.ThemeChangedDockWindowManagerEventArgs –> The instance containing the event data.
OpenDockWindowCore(DockWindow, DockWindowPosition)
ActiveDocumentIndex
Return Type
DockWindows
Return Type
ObservableCollection<DockWindow><!– System.Collections.ObjectModel.ObservableCollection{ThinkGeo.MapSuite.GisEditor.DockWindow} –>
DocumentWindows
Return Type
ObservableCollection<DocumentWindow><!– System.Collections.ObjectModel.ObservableCollection{ThinkGeo.MapSuite.GisEditor.DocumentWindow} –>
Theme
Return Type
Theme<!– ThinkGeo.MapSuite.GisEditor.Theme –>
DockWindowOpened
Event Arguments
Event Arguments
SortedDockWindows
Event Arguments
Event Arguments
SortedDockWindowsEventArgs<!– ThinkGeo.MapSuite.GisEditor.SortedDockWindowsEventArgs –>
SortingDockWindows
Event Arguments
Event Arguments
SortingDockWindowsEventArgs<!– ThinkGeo.MapSuite.GisEditor.SortingDockWindowsEventArgs –>
ThemeChanged
Event Arguments
Event Arguments
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
thinkgeo.mapsuite.giseditor.dockwindowmanager.txt · Last modified: 2017/03/16 21:59 (external edit)
