<!– Class –>
*System.Object **ThinkGeo.MapSuite.GisEditor.DocumentWindow
DocumentWindow | Initializes a new instance of the class. | ||
DocumentWindow | Control | Initializes a new instance of the class. | |
DocumentWindow | Control, String | Initializes a new instance of the class. | |
DocumentWindow | Control, String, String | Initializes a new instance of the class. | |
DocumentWindow | Control, String, String, Boolean | Initializes a new instance of the class. |
| content | Control<!– System.Windows.Controls.Control –> | The content. |
| title | String<!– System.String –> | The title. |
| name | String<!– System.String –> | The name. |
| canFloat | Boolean<!– System.Boolean –> | if set to true float. |
Gets or sets a value indicating whether this instance can float.
<!– ThinkGeo.MapSuite.GisEditor.DocumentWindow –> Go Back
Gets or sets the content.
Gets or sets the name.
Gets or sets the title.
