thinkgeo.mapsuite.desktopedition.mapleftclickdragmode
ThinkGeo.MapSuite.DesktopEdition.MapLeftClickDragMode
  • This enumeration specifies the behavior that occurs when you left-click-and-drag on the MapControl. The default value is ZoomInWithKey.
  • For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapLeftClickDragMode// == Items == Default * Summary:Default value(ZoomInWithKey) of enumeration. ZoomInWithKey * Summary:This enumeration item means that the map will ZoomIn when a left-click-and-drag operation occurs. Disabled * Summary:This enumeration item means that the ZoomIn functionality for left-clicking-and-dragging will be disabled.
thinkgeo.mapsuite.desktopedition.mapleftclickdragmode.txt · Last modified: 2017/03/16 21:59 (external edit)
