thinkgeo.mapsuite.desktopedition.mapmousewheelmode
ThinkGeo.MapSuite.DesktopEdition.MapMouseWheelMode
  • This enumeration specifies the behavior that occurs when the mouse wheel is scrolled. The default value is Zooming.
  • For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseWheelMode// == Items == Default * Summary:Default value (Zooming) of the enumeration. Zooming * Summary:This enumeration item means that the map will ZoomIn or ZoomOut when the mouse wheel is scrolled up or down, respectively. Disabled * Summary:This enumeration item means that the mouse wheel will be disabled and will have no effect on the MapControl.
thinkgeo.mapsuite.desktopedition.mapmousewheelmode.txt · Last modified: 2017/03/16 21:59 (external edit)
