map_suite_windows_phone_edition_faq_layers_featuresources
Map Suite Windows Phone Edition FAQ Layers & FeatureSources
How do I efficiently display a subset of a shape file without splitting it?
How do I display highways and local roads using different symbols from the same shape file?
How do I draw a north arrow on my map?
Sample:Compass
We also added new designs of compass in smaller version. See the attached file: Rotating Compass New Smaller Designs.zip.
How do I display graphs and charts on the map?
Sample:Zedgraph
In our “How Do I” apps, there is sample app that shows how to add graphs to the map using the ZedGraph library. In this project, using the same data, the US cities, we elaborate a little bit on the pie chart. You will see how to add some gradient colors to the chart, how to label the different pie slices, how to add a title etc. Zedgraph is a truly massive library for graphics and Pie chart is only one type of chart among many others. As you can add pie charts to your map, you can also add bar charts, trend charts etc. I suggest you check out this site for more info on ZedGraph
http://zedgraph.org/wiki/index.php?title=Main_Page
With Map Suite, you have the whole ZedGraph API available with an easy interface to add the graphs to the map.
For this project, in addition to the MapSuiteCore.dll, you will also need the ZedGraph.dll and ZedGraphStyleExtension.dll references. We will have several projects showing how to integrate other types of charts to your map.
How do I add a watermark to the map?
How do I encrypt a shape file for security?
Sample:Shapefile Encryption
How do I get geometry data from the server using WCF?
How do I display a scale bar using custom units?
Sample:Scale Bar
How can I show my own logo on the map?
Sample:Graphic Logo for Web
How do I display heat map?
Sample:Heat Map
How can I load an image from a stream rather than a file?
Sample:Image Stream Loading
How can I draw KML on the map?
Sample:KML Extension Web
How do I display latitude and longitude graticule lines?
How can I display a legend on my map?
Sample:Legend Adornment Layer
How do I show a mini map?
How do I display multi geo-raster files as one layer?
Sample:Multi Geo Raster Layer
How do I work with multi index files?
Sample:Multi Index
How do I display point data from an OLE DB complied data source?
In this project, we create the class OledbPointFeatureSource inheriting from FeatureSource and OledbPointFeatureLayer inheriting from FeatureSource.
How do I create a numbered grid for a given extent?
Sample:Numbered Grid
How do I draw a north facing arrow when using rotation?
Sample:North Arrow
Displaying the North Arrow:
How to use a common FeatureSource for two different Overlays?
Sample:Combining Overlays
How to edit the geometry of a shapefile?
How to edit attribute of a shapefile?
How to create GRID?
Sample:Create GRID
map_suite_windows_phone_edition_faq_layers_featuresources.txt · Last modified: 2015/09/16 08:02 by admin
