KeyUp(KeyEventInteractionArguments)
MouseDown(InteractionArguments)
MouseMove(InteractionArguments)
MouseClick(InteractionArguments)
MouseDoubleClick(InteractionArguments)
MouseWheel(InteractionArguments)
Refresh(GeoCanvas,RectangleShape)
MouseDownCore(InteractionArguments)
MouseUpCore(InteractionArguments)
MouseClickCore(InteractionArguments)
KeyDownCore(KeyEventInteractionArguments)
KeyUpCore(KeyEventInteractionArguments)
MouseDoubleClickCore(InteractionArguments)
MouseWheelCore(InteractionArguments)
OnMapMouseDown(MapMouseDownInteractiveOverlayEventArgs)
OnMapMouseMove(MapMouseMoveInteractiveOverlayEventArgs)
OnMapMouseUp(MapMouseUpInteractiveOverlayEventArgs)
OnMapMouseClick(MapMouseClickInteractiveOverlayEventArgs)
OnMapMouseDoubleClick(MapMouseDoubleClickInteractiveOverlayEventArgs)
OnMapMouseWheel(MapMouseWheelInteractiveOverlayEventArgs)
OnMapKeyDown(MapKeyDownInteractiveOverlayEventArgs)
OnMapKeyUp(MapKeyUpInteractiveOverlayEventArgs)
OnDrawing(DrawingOverlayEventArgs)
OnDrawn(DrawnOverlayEventArgs)
RefreshCore(GeoCanvas,RectangleShape)
OnRequestedDrawing(RequestedDrawingOverlayEventArgs)
IsEditable
* N/A
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PrinterInteractiveOverLay#IsEditable//
ControlPointStyle
* N/A
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PrinterInteractiveOverLay#ControlPointStyle//
Attribution
* N/A
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PrinterInteractiveOverLay#DrawAttributionCore.28GeoCanvas.29//
IsBase
* Gets or sets a value that indicates whether the overlay is a base overlay. The default value is false.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PrinterInteractiveOverLay#IsBase//
IsVisible
* Gets or sets a value that indicates whether the overlay is visible on the map.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PrinterInteractiveOverLay#IsVisible//
TileCache
* This property gets or sets the TileCache used for the overlay.
== Remarks ==
* The TileCache system is always used for better performance, especially in the case where your application tiles can be pregenerated.
== Return Value ==
* Type:BitmapTileCache
PreviewTileCache
* This property gets or sets the preview tile cache system. In order for this system to work, you must be in multi-threaded mode and have the tile cache set.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PrinterInteractiveOverLay#PreviewTileCache//
MapMouseMove
* This event will be fired when the Mouse is moved on the Map.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PrinterInteractiveOverLay#OnMapMouseMove.28MapMouseMoveInteractiveOverlayEventArgs.29//Event Arguments:MapMouseMoveInteractiveOverlayEventArgs
MapMouseClick
* This event will be fired when the Mouse button is clicked (mouse up and mouse down in the same postion) on the Map.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PrinterInteractiveOverLay#OnMapMouseClick.28MapMouseClickInteractiveOverlayEventArgs.29//Event Arguments:MapMouseClickInteractiveOverlayEventArgs
MapMouseWheel
* This event will be fired when the Mouse wheel is scrolled while the cursor is over the Map.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PrinterInteractiveOverLay#OnMapMouseWheel.28MapMouseWheelInteractiveOverlayEventArgs.29//Event Arguments:MapMouseWheelInteractiveOverlayEventArgs
MapKeyUp
* This event will be fired when the key is released up when focusing on the Map.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PrinterInteractiveOverLay#OnMapKeyUp.28MapKeyUpInteractiveOverlayEventArgs.29//Event Arguments:MapKeyUpInteractiveOverlayEventArgs
Drawn
* This event will be fired after the Overlay is drawn.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PrinterInteractiveOverLay#OnDrawn.28DrawnOverlayEventArgs.29//Event Arguments:DrawnOverlayEventArgs
DrawnAttribution
* N/A
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.PrinterInteractiveOverLay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29//Event Arguments:DrawnAttributionOverlayEventArgs
Event Arguments:RequestedDrawingOverlayEventArgs
Event Arguments:RequestingDrawingOverlayEventArgs
