thinkgeo.mapsuite.silverlightedition.interactiveoverlay
ThinkGeo.MapSuite.SilverlightEdition.InteractiveOverlay
This class inherits from Overlay abstract class. This specified overlay describle the interative process with MapControl using Mouse or Keyborad.
InteractiveOverlay()
  • Default constructor of this abstract class.
MouseDown(InteractionArguments)
  • This method will simulate the MouseDown interaction.
  • This method is the concrete wrapper for its virtual Core method. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • interactionArguments
MouseMove(InteractionArguments)
  • This method will simulate the MouseMove interaction.
MouseUp(InteractionArguments)
  • This method will simulate the MouseUp interaction.
MouseClick(InteractionArguments)
  • This method will simulate the MouseClick interaction.
MouseDoubleClick(InteractionArguments)
  • This method will simulate the MouseDoubleClick interaction.
MouseWheel(InteractionArguments)
  • This method will simulate the MouseWheel interaction.
Refresh()
Draw(RectangleShape,OverlayDrawType)
Initialize(Map)
  • currentMap
    • Type:Map
ToWorldCoordinate(Double,Double)
  • screenX
  • screenY
ToWorldCoordinate(PointShape)
  • screenCoordinate
ToWorldCoordinate(Point)
  • screenCoordinate
    • Type:Point
ToScreenCoordinate(Double,Double)
  • worldX
  • worldY
ToScreenCoordinate(PointShape)
ToScreenCoordinate(Point)
  • worldCoordinate
    • Type:Point
MouseDownCore(InteractionArguments)
  • This protected virtual method is the Core method of MouseDown API.
MouseMoveCore(InteractionArguments)
  • This protected virtual method is the Core method of MouseMove API.
MouseUpCore(InteractionArguments)
  • This protected virtual method is the Core method of MouseUp API.
MouseClickCore(InteractionArguments)
  • This protected virtual method is the Core method of MouseClick API.
MouseDoubleClickCore(InteractionArguments)
  • This protected virtual method is the Core method of MouseDoubleClick API.
MouseWheelCore(InteractionArguments)
  • This protected virtual method is the Core method of MouseWheel API.
OnMapMouseDown(MapMouseDownInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseDown is called.
OnMapMouseMove(MapMouseMoveInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseMove is called.
OnMapMouseUp(MapMouseUpInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseUp is called.
OnMapMouseClick(MapMouseClickInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseClick is called.
OnMapMouseDoubleClick(MapMouseDoubleClickInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseDoubleClick is called.
OnMapMouseWheel(MapMouseWheelInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseWheel is called.
DrawCore(RectangleShape)
  • This method draws the InterativeInterativeOverlay abstract class. You have to override this API in its sub concrete classes, or it will throw NotImplementedException.
  • Description:None
  • worldExtent
    • Description:This parameter is the canvas object or a GeoImage to draw on.
DxU=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
ZoomStoryCompletedCore()
PanAnimationCompletedCore()
InitializeCore()
MouseMoveInterval
  • Type:TimeSpan
Visibility
  • Type:Visibility
OverlayElement
  • Type:FrameworkElement
Attribution
TransitionEffect
Opacity
ZIndex
StoryboardForZooming
  • Type:Storyboard
StoryboardForPanning
  • Type:Storyboard
PanFrameX
  • Type:SplineDoubleKeyFrame
PanFrameY
ZoomFrameX
ZoomFrameY
MapInfo
TranslateTransform
  • Type:TranslateTransform
ScaleTransform
  • Type:ScaleTransform
TransformGroup
  • Type:TransformGroup
MapMouseDown This event will be fired when Mouse pressed Down on the Map.
Event Arguments:MapMouseDownInteractiveOverlayEventArgs
MapMouseMove This event will be fired when Mouse moved on the Map.
Event Arguments:MapMouseMoveInteractiveOverlayEventArgs
MapMouseUp This event will be fired when Mouse released up on the Map.
Event Arguments:MapMouseUpInteractiveOverlayEventArgs
MapMouseClick This event will be fired when Mouse clicked(mouse up and mouse down in the same postion) on the Map.
Event Arguments:MapMouseClickInteractiveOverlayEventArgs
MapMouseDoubleClick This event will be fired when Mouse double clicked on the Map.
Event Arguments:MapMouseDoubleClickInteractiveOverlayEventArgs
MapMouseWheel This event will be fired when Mouse wheel on the Map.
Event Arguments:MapMouseWheelInteractiveOverlayEventArgs
DrawingAttribution N/A
Event Arguments:DrawingAttributionOverlayEventArgs
DrawnAttribution N/A
Event Arguments:DrawnAttributionOverlayEventArgs
thinkgeo.mapsuite.silverlightedition.interactiveoverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
