<!– Class –> This class represents style plugin
StylePlugin | Initializes a new instance of the class. |
ApplySettings | StorableSettings | Plugin | Applies the settings to this plugin. |
GetDefaultStyle | Gets the default style. | ||
GetSettings | Plugin | Gets plugin settings to save. | |
GetSettingsUI | Plugin | Gets an UI that configures settings. | |
GetStyleLayerListItem | Style | Gets the style layer list item. | |
Load | Plugin | This method raises when load this plugin. | |
ToString | Object | ||
Unload | Plugin | This method raises when unload this plugin. |
ApplySettingsCore | StorableSettings | Plugin | Applies the settings to this plugin. |
GetDefaultStyleCore | Gets the default style core. | ||
GetSettingsCore | Plugin | Gets plugin settings to save. | |
GetSettingsUICore | Plugin | Gets an UI that configures settings. | |
GetStyleLayerListItemCore | Style | Gets the style layer list item core. | |
LoadCore | Plugin | This method raises when load this plugin. | |
MemberwiseClone | Object | ||
UnloadCore | Plugin | This method raises when unload this plugin. |
Author | String | Plugin | Gets or sets author information for plugin. |
Description | String | Plugin | Gets or sets description for plugin. |
Id | String | Plugin | Gets the identify of plugin. |
Index | Int32 | Plugin | Gets or sets the index of the plugin. |
IsActive | Boolean | Plugin | Gets or sets a value indicating whether this plugin is active. |
IsDefault | Boolean | This property gets a priority for getting back the provider where querying style providers. None-default style provider will be selected first; if none-provider is selected, choose default provider. So the default provider has larger range for founding provider from style. | |
IsRequired | Boolean | Plugin | Gets or sets a value indicating whether this plugin is required. |
LargeIcon | ImageSource | Plugin | Gets or sets large icon for plugin. |
Name | String | Plugin | Gets or sets the name of plugin. |
RequireColumnNames | Boolean | Gets or sets a value indicating whether column names. | |
SmallIcon | ImageSource | Plugin | Gets or sets small icon path for plugin. |
StyleCategories | StyleCategories | Gets or sets the style categories. | |
UseRandomColor | Boolean | Gets or sets a value indicating whether random color. |
| settings | StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | The settings to be applied to this plugin. |
<!– ThinkGeo.MapSuite.GisEditor.Plugin –> Go Back
| Style<!– ThinkGeo.MapSuite.Core.Style –> | Default style |
<!– ThinkGeo.MapSuite.GisEditor.StylePlugin –> Go Back
| StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | Plugin's settings to save. |
| SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> | A SettingUserControl that configures settings. |
| StyleLayerListItem<!– ThinkGeo.MapSuite.GisEditor.StyleLayerListItem –> | a list item for style layer |
| style | Style<!– ThinkGeo.MapSuite.Core.Style –> | The style. |
<remarks> Plugins are orded by this property. </remarks>
<remarks> Setting relative path to this property to discover image. Path should be like the form of FolderName(optional)/ImageFullName, such as “Images/NewContent.png” or “Content.png”. Make sure that image you supplied compiling with Build Action Resource. </remarks>
| ImageSource<!– System.Windows.Media.ImageSource –> |
| StyleCategories<!– ThinkGeo.MapSuite.GisEditor.StyleCategories –> |
