<!– Class –>
*System.Object **ThinkGeo.MapSuite.Core.CogoDirectionHelper
![]() CalculateDestination | PointShape, Double, Double, DistanceUnit | ||
![]() ConvertDirectionUnit | String, CogoDirectionType, CogoDirectionUnit, CogoDirectionType, CogoDirectionUnit | ||
![]() ConvertDirectionUnit | String, CogoDirectionUnit, CogoDirectionUnit | ||
![]() ConvertDirectionUnitFromDegree | Double, CogoDirectionUnit | ||
![]() ConvertDirectionUnitToDegree | String, CogoDirectionUnit | ||
<!– static –>
| PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> |
| startPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
| bearingInDegree | Double<!– System.Double –> | |
| distance | Double<!– System.Double –> | |
| distanceUnit | DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> |
<!– ThinkGeo.MapSuite.Core.CogoDirectionHelper –> Go Back
<!– static –>
| fromDirection | String<!– System.String –> | |
| fromDirectionType | CogoDirectionType<!– ThinkGeo.MapSuite.Core.CogoDirectionType –> | |
| fromDirectionUnit | CogoDirectionUnit<!– ThinkGeo.MapSuite.Core.CogoDirectionUnit –> | |
| toDirectionType | CogoDirectionType<!– ThinkGeo.MapSuite.Core.CogoDirectionType –> | |
| toDirectionUnit | CogoDirectionUnit<!– ThinkGeo.MapSuite.Core.CogoDirectionUnit –> |
<!– static –>
<!– static –>
| fromDirectionInDegree | Double<!– System.Double –> | |
<!– static –>
