thinkgeo.mapsuite.giseditor.layerlistmanager
ThinkGeo.MapSuite.GisEditor.LayerListManager
<!– Class –>
Public MethodLayerListManager Initializes a new instance of the class.
Public MethodApplySettings StorableSettings Manager Applies the settings to this manager.
Public MethodGetLayerListContextMenuItems LayerListItem
Public MethodGetRootLayerListItem GisEditorWpfMap Gets the root layer list item.
Public MethodGetSettings Manager Gets manager settings to save.
Public MethodGetSettingsUI Manager Gets an UI that configures settings.
Public MethodGetType Object
Public MethodToString Object
Public PropertySelectedLayerListItem LayerListItem Gets or sets the selected layer list item.
Public PropertySelectedLayerListItems Collection<LayerListItem> Gets the selected layer list items.
LayerListManager()
Name Type Description
Go Back
ApplySettings(StorableSettings)
Return Type Description
Void<!– System.Void –>
settings StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> The settings to be applied to this manager.
<!– ThinkGeo.MapSuite.GisEditor.Manager –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetLayerListContextMenuItems(LayerListItem)
ObservableCollection<MenuItem><!– System.Collections.ObjectModel.ObservableCollection{System.Windows.Controls.MenuItem} –>
layerListItem LayerListItem<!– ThinkGeo.MapSuite.GisEditor.LayerListItem –>
<!– ThinkGeo.MapSuite.GisEditor.LayerListManager –> Go Back
GetRootLayerListItem(GisEditorWpfMap)
wpfMap GisEditorWpfMap<!– ThinkGeo.MapSuite.WpfDesktopEdition.Extension.GisEditorWpfMap –> The WPF map.
GetSettings()
StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> Manager's settings to save
GetSettingsUI()
SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> A SettingUserControl that configures settings.
Type<!– System.Type –>
String<!– System.String –>
ApplySettingsCore(StorableSettings)
Applies the settings core.
settings StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> The settings.
<!– ThinkGeo.MapSuite.GisEditor.Manager(overriden) –> Go Back
GetLayerListContextMenuItemsCore(LayerListItem)
GetRootLayerListItemCore(GisEditorWpfMap)
Gets the root layer list item core.
GetSettingsCore()
Gets the settings core.
GetSettingsUICore()
OnGettingLayerListItemContextMenuItems(GettingLayerListItemContextMenuItemsEventArgs)
e GettingLayerListItemContextMenuItemsEventArgs<!– ThinkGeo.MapSuite.GisEditor.GettingLayerListItemContextMenuItemsEventArgs –>
OnGottenLayerListItemContextMenuItems(GottenLayerListItemContextMenuItemsEventArgs)
e GottenLayerListItemContextMenuItemsEventArgs<!– ThinkGeo.MapSuite.GisEditor.GottenLayerListItemContextMenuItemsEventArgs –>
OnSelectedLayerListItemChanged(SelectedLayerListItemChangedLayerListManagerEventArgs)
e SelectedLayerListItemChangedLayerListManagerEventArgs<!– ThinkGeo.MapSuite.GisEditor.SelectedLayerListItemChangedLayerListManagerEventArgs –>
Return Type
Return Type
Collection<LayerListItem><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.GisEditor.LayerListItem} –>
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
thinkgeo.mapsuite.giseditor.layerlistmanager.txt · Last modified: 2017/03/16 21:59 (external edit)
