thinkgeo.mapsuite.giseditor.gottenlayerlistitemcontextmenuitemseventargs
ThinkGeo.MapSuite.GisEditor.GottenLayerListItemContextMenuItemsEventArgs
<!– Class –>
Public MethodGottenLayerListItemContextMenuItemsEventArgs
Public MethodGottenLayerListItemContextMenuItemsEventArgs ObservableCollection<MenuItem>
Public MethodGetType Object
Public MethodToString Object
Public PropertyMenuItems ObservableCollection<MenuItem>
GottenLayerListItemContextMenuItemsEventArgs()
Name Type Description
Go Back
GottenLayerListItemContextMenuItemsEventArgs(ObservableCollection<MenuItem>)
layerListMenuItems ObservableCollection<MenuItem><!– System.Collections.ObjectModel.ObservableCollection{System.Windows.Controls.MenuItem} –>
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Return Type
<!– ThinkGeo.MapSuite.GisEditor.GottenLayerListItemContextMenuItemsEventArgs –> Go Back
thinkgeo.mapsuite.giseditor.gottenlayerlistitemcontextmenuitemseventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
