<!– Class –>
*System.Object System.EventArgs *System.ComponentModel.CancelEventArgs ThinkGeo.MapSuite.GisEditor.GettingLayerListItemContextMenuItemsEventArgs
GettingLayerListItemContextMenuItemsEventArgs | |||
GettingLayerListItemContextMenuItemsEventArgs | ObservableCollection<MenuItem> |
| layerListMenuItems | ObservableCollection<MenuItem><!– System.Collections.ObjectModel.ObservableCollection{System.Windows.Controls.MenuItem} –> |
<!– System.ComponentModel.CancelEventArgs –> Go Back
<!– ThinkGeo.MapSuite.GisEditor.GettingLayerListItemContextMenuItemsEventArgs –> Go Back
