<!– Class –>
UpdateManager | Initializes a new instance of the class. |
ApplySettings | StorableSettings | Manager | Applies the settings to this manager. |
GetSettings | Manager | Gets manager settings to save. | |
GetSettingsUI | Manager | Gets an UI that configures settings. | |
ToString | Object | ||
Update | Update based on the options. | ||
Update | UpdateMode | Update based on the specified parameter. |
ApplySettingsCore | StorableSettings | Manager(overriden) | Applies the settings core. |
GetSettingsCore | Manager(overriden) | Gets the settings core. | |
GetSettingsUICore | Manager(overriden) | Gets the settings UI core. | |
MemberwiseClone | Object | ||
UpdateCore | UpdateMode | Updates the core. |
TargetUpdateChannel | UpdateChannel | Gets or sets the target update channel. | |
UpdateChannels | Collection<UpdateChannel> | Gets the update channels. | |
UpdateMode | UpdateMode | Gets or sets the update mode. |
| settings | StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | The settings to be applied to this manager. |
<!– ThinkGeo.MapSuite.GisEditor.Manager –> Go Back
| StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | Manager's settings to save |
| SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> | A SettingUserControl that configures settings. |
<!– ThinkGeo.MapSuite.GisEditor.UpdateManager –> Go Back
| mode | UpdateMode<!– ThinkGeo.MapSuite.GisEditor.UpdateMode –> |
| settings | StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | The settings. |
<!– ThinkGeo.MapSuite.GisEditor.Manager(overriden) –> Go Back
Updates the core.
| mode | UpdateMode<!– ThinkGeo.MapSuite.GisEditor.UpdateMode –> | The mode. |
| UpdateChannel<!– ThinkGeo.MapSuite.GisEditor.UpdateChannel –> |
| Collection<UpdateChannel><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.GisEditor.UpdateChannel} –> |
