thinkgeo.mapsuite.giseditor.loggingloggermanagereventargs
ThinkGeo.MapSuite.GisEditor.LoggingLoggerManagerEventArgs
<!– Class –>
Public MethodLoggingLoggerManagerEventArgs Initializes a new instance of the class.
Public MethodLoggingLoggerManagerEventArgs LoggerMessage Initializes a new instance of the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyLoggerMessage LoggerMessage Gets or sets the logger message.
LoggingLoggerManagerEventArgs()
Name Type Description
Go Back
LoggingLoggerManagerEventArgs(LoggerMessage)
loggerMessage LoggerMessage<!– ThinkGeo.MapSuite.GisEditor.LoggerMessage –> The logger message.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
LoggerMessage
Return Type
<!– ThinkGeo.MapSuite.GisEditor.LoggingLoggerManagerEventArgs –> Go Back
thinkgeo.mapsuite.giseditor.loggingloggermanagereventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
