<!– Class –>
*System.Object GalaSoft.MvvmLight.ObservableObject *GalaSoft.MvvmLight.ViewModelBase ThinkGeo.MapSuite.GisEditor.QueryConditionViewModel
QueryConditionViewModel |
Cleanup | ViewModelBase | ||
CloneDeep | |||
ToString | Object | ||
VerifyPropertyName | String | ObservableObject |
Broadcast | T, T, String | ViewModelBase | |
MemberwiseClone | Object | ||
RaisePropertyChanged | Expression<Func<T» | ObservableObject | |
RaisePropertyChanged | Expression<Func<T», T, T, Boolean | ViewModelBase | |
RaisePropertyChanged | String, T, T, Boolean | ViewModelBase | |
RaisePropertyChanged | String | ObservableObject | |
Set | String, ref T, T, Boolean | ViewModelBase | |
Set | Expression<Func<T», ref T, T | ObservableObject | |
Set | String, ref T, T | ObservableObject | |
Set | Expression<Func<T», ref T, T, Boolean | ViewModelBase |
CancelCommand | ObservedCommand | ||
ColumnName | String | ||
ConfirmCommand | ObservedCommand | ||
FeatureLayers | List<FeatureLayer> | ||
IsInDesignMode | Boolean | ViewModelBase | |
Layer | FeatureLayer | ||
MatchValue | String | ||
QueryOperator | QueryOperater | ||
QueryOperators | ObservableCollection<QueryOperater> | ||
ReadableText | String |
MessengerInstance | IMessenger | ViewModelBase | |
PropertyChangedHandler | PropertyChangedEventHandler | ObservableObject |
PropertyChanged | PropertyChangedEventArgs | ObservableObject |
<!– GalaSoft.MvvmLight.ViewModelBase –> Go Back
| QueryConditionViewModel<!– ThinkGeo.MapSuite.GisEditor.QueryConditionViewModel –> |
<!– ThinkGeo.MapSuite.GisEditor.QueryConditionViewModel –> Go Back
| propertyName | String<!– System.String –> |
<!– GalaSoft.MvvmLight.ObservableObject –> Go Back
| oldValue | T<!– T –> | |
| newValue | T<!– T –> | |
| propertyExpression | Expression<Func<T»<!– Expression{Func{T}} –> |
| propertyExpression | Expression<Func<T»<!– Expression{Func{T}} –> | |
| broadcast | Boolean<!– System.Boolean –> |
| propertyName | String<!– System.String –> | |
| field | ref T<!– T –> | |
| ObservedCommand<!– ThinkGeo.MapSuite.GisEditor.ObservedCommand –> |
| List<FeatureLayer><!– System.Collections.Generic.List{ThinkGeo.MapSuite.Core.FeatureLayer} –> |
| FeatureLayer<!– ThinkGeo.MapSuite.Core.FeatureLayer –> |
| QueryOperater<!– ThinkGeo.MapSuite.GisEditor.QueryOperater –> |
| ObservableCollection<QueryOperater><!– System.Collections.ObjectModel.ObservableCollection{ThinkGeo.MapSuite.GisEditor.QueryOperater} –> |
| IMessenger<!– GalaSoft.MvvmLight.Messaging.IMessenger –> |
| PropertyChangedEventHandler<!– System.ComponentModel.PropertyChangedEventHandler –> |
| Event Arguments |
| PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –> |
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
