<!– Class –> This class contains some global objects will be accessed by both shell and plugins.
*System.Object **ThinkGeo.MapSuite.GisEditor.GisEditor
![]() GetMaps | |||
![]() ActiveMap | GisEditorWpfMap | This static property gets or sets the map that is activated. | |
![]() ControlManager | ControlPluginManager | ||
![]() DataRepositoryManager | DataRepositoryPluginManager | ||
![]() DockWindowManager | DockWindowManager | ||
![]() InfrastructureManager | InfrastructureManager | ||
![]() LanguageManager | LanguageManager | ||
![]() LayerListManager | LayerListManager | ||
![]() LayerManager | LayerPluginManager | ||
![]() LoggerManager | LoggerPluginManager | ||
![]() ProjectManager | ProjectPluginManager | ||
![]() SelectionManager | SelectionManager | ||
![]() StyleManager | StylePluginManager | ||
![]() TaskManager | TaskPluginManager | ||
![]() UIManager | UIPluginManager | ||
![]() UpdateManager | UpdateManager |
<!– static –>
| Collection<GisEditorWpfMap><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WpfDesktopEdition.Extension.GisEditorWpfMap} –> |
<!– ThinkGeo.MapSuite.GisEditor.GisEditor –> Go Back
<!– static –> This static property gets or sets the map that is activated.
<remarks> This property changes automatically when you switch your tabs. One tab maintains only one map, so the map is changed when the tab is changed. You can add any kind of overlay during overriding plugins; please clear the overlays you added before exiting the main application. </remarks>
| GisEditorWpfMap<!– ThinkGeo.MapSuite.WpfDesktopEdition.Extension.GisEditorWpfMap –> |
<!– static –>
| ControlPluginManager<!– ThinkGeo.MapSuite.GisEditor.ControlPluginManager –> |
<!– static –>
| DataRepositoryPluginManager<!– ThinkGeo.MapSuite.GisEditor.DataRepositoryPluginManager –> |
<!– static –>
| DockWindowManager<!– ThinkGeo.MapSuite.GisEditor.DockWindowManager –> |
<!– static –>
| InfrastructureManager<!– ThinkGeo.MapSuite.GisEditor.InfrastructureManager –> |
<!– static –>
| LanguageManager<!– ThinkGeo.MapSuite.GisEditor.LanguageManager –> |
<!– static –>
| LayerListManager<!– ThinkGeo.MapSuite.GisEditor.LayerListManager –> |
<!– static –>
| LayerPluginManager<!– ThinkGeo.MapSuite.GisEditor.LayerPluginManager –> |
<!– static –>
| LoggerPluginManager<!– ThinkGeo.MapSuite.GisEditor.LoggerPluginManager –> |
<!– static –>
| ProjectPluginManager<!– ThinkGeo.MapSuite.GisEditor.ProjectPluginManager –> |
<!– static –>
| SelectionManager<!– ThinkGeo.MapSuite.GisEditor.SelectionManager –> |
<!– static –>
| StylePluginManager<!– ThinkGeo.MapSuite.GisEditor.StylePluginManager –> |
<!– static –>
| TaskPluginManager<!– ThinkGeo.MapSuite.GisEditor.TaskPluginManager –> |
<!– static –>
| UIPluginManager<!– ThinkGeo.MapSuite.GisEditor.UIPluginManager –> |
<!– static –>
| UpdateManager<!– ThinkGeo.MapSuite.GisEditor.UpdateManager –> |
