<!– Class –> This class represents contex menu arguments for layer list item
*System.Object **ThinkGeo.MapSuite.GisEditor.GetLayerListItemContextMenuParameters
GetLayerListItemContextMenuParameters | Initializes a new instance of the class. | ||
GetLayerListItemContextMenuParameters | LayerListItem | Initializes a new instance of the class. |
LayerListItem | LayerListItem | Gets or sets the layer list item. |
| layerListItem | LayerListItem<!– ThinkGeo.MapSuite.GisEditor.LayerListItem –> | The layer list item. |
<!– ThinkGeo.MapSuite.GisEditor.GetLayerListItemContextMenuParameters –> Go Back
