<!– Class –>
*System.Object GalaSoft.MvvmLight.ObservableObject *GalaSoft.MvvmLight.ViewModelBase ThinkGeo.MapSuite.GisEditor.SimpleQueryViewModel
SimpleQueryViewModel |
Cleanup | ViewModelBase | ||
FindFeaturesByKeyword | String, IEnumerable<FeatureLayer> | ||
ToString | Object | ||
VerifyPropertyName | String | ObservableObject |
Broadcast | T, T, String | ViewModelBase | |
MemberwiseClone | Object | ||
RaisePropertyChanged | Expression<Func<T» | ObservableObject | |
RaisePropertyChanged | Expression<Func<T», T, T, Boolean | ViewModelBase | |
RaisePropertyChanged | String, T, T, Boolean | ViewModelBase | |
RaisePropertyChanged | String | ObservableObject | |
Set | String, ref T, T, Boolean | ViewModelBase | |
Set | Expression<Func<T», ref T, T | ObservableObject | |
Set | String, ref T, T | ObservableObject | |
Set | Expression<Func<T», ref T, T, Boolean | ViewModelBase |
AddressToSearch | String | ||
AvailableFeatureLayers | ObservableCollection<CheckableItemViewModel<FeatureLayer» | ||
CancelCommand | RelayCommand | ||
FindCommand | ObservedCommand | ||
IsInDesignMode | Boolean | ViewModelBase | |
SelectAllCommand | RelayCommand<Boolean> |
MessengerInstance | IMessenger | ViewModelBase | |
PropertyChangedHandler | PropertyChangedEventHandler | ObservableObject |
PropertyChanged | PropertyChangedEventArgs | ObservableObject |
<!– GalaSoft.MvvmLight.ViewModelBase –> Go Back
| Collection<Feature><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.Feature} –> |
| addressToSearch | String<!– System.String –> | |
| selectedLayers | IEnumerable<FeatureLayer><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.FeatureLayer} –> |
<!– ThinkGeo.MapSuite.GisEditor.SimpleQueryViewModel –> Go Back
| propertyName | String<!– System.String –> |
<!– GalaSoft.MvvmLight.ObservableObject –> Go Back
| oldValue | T<!– T –> | |
| newValue | T<!– T –> | |
| propertyExpression | Expression<Func<T»<!– Expression{Func{T}} –> |
| propertyExpression | Expression<Func<T»<!– Expression{Func{T}} –> | |
| broadcast | Boolean<!– System.Boolean –> |
| propertyName | String<!– System.String –> | |
| field | ref T<!– T –> | |
| ObservableCollection<CheckableItemViewModel<FeatureLayer»<!– System.Collections.ObjectModel.ObservableCollection{ThinkGeo.MapSuite.GisEditor.CheckableItemViewModel{ThinkGeo.MapSuite.Core.FeatureLayer}} –> |
| RelayCommand<!– GalaSoft.MvvmLight.Command.RelayCommand –> |
| ObservedCommand<!– ThinkGeo.MapSuite.GisEditor.ObservedCommand –> |
| RelayCommand<Boolean><!– GalaSoft.MvvmLight.Command.RelayCommand{System.Boolean} –> |
| IMessenger<!– GalaSoft.MvvmLight.Messaging.IMessenger –> |
| PropertyChangedEventHandler<!– System.ComponentModel.PropertyChangedEventHandler –> |
| Event Arguments |
| PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –> |
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
