thinkgeo.mapsuite.giseditor.refreshargs
ThinkGeo.MapSuite.GisEditor.RefreshArgs
<!– Class –>
Public MethodRefreshArgs Initializes a new instance of the class.
Public MethodRefreshArgs Object Initializes a new instance of the class.
Public MethodRefreshArgs Object, String Initializes a new instance of the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyDescription String
Public PropertySender Object Gets or sets the sender.
RefreshArgs()
Name Type Description
Go Back
RefreshArgs(Object)
sender Object<!– System.Object –> The sender.
Go Back
RefreshArgs(Object, String)
description String<!– System.String –>
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
Void<!– System.Void –>
Description
Return Type
<!– ThinkGeo.MapSuite.GisEditor.RefreshArgs –> Go Back
Sender
Return Type
thinkgeo.mapsuite.giseditor.refreshargs.txt · Last modified: 2017/03/16 21:59 (external edit)
