thinkgeo.mapsuite.giseditor.dataviewerhelper
ThinkGeo.MapSuite.GisEditor.DataViewerHelper
<!– Class –>
Public PropertyStatic MemberSavedConditions ObservableCollection<QueryConditionViewModel>
CloseQueryWindow()
<!– static –>
Return Type Description
Void<!– System.Void –>
Name Type Description
<!– ThinkGeo.MapSuite.GisEditor.DataViewerHelper –> Go Back
Boolean<!– System.Boolean –>
GetDockingManager()
<!– static –>
DockingManager<!– AvalonDock.DockingManager –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
OpenQueryWindow()
<!– static –>
ShowDbfViewer(IEnumerable<FeatureLayer>, FeatureLayer, DbfViewerShowSelectedFeaturesMode, DbfViewerEditMode, DbfViewerDockingMode)
<!– static –>
allLayers IEnumerable<FeatureLayer><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.FeatureLayer} –>
selectedLayer FeatureLayer<!– ThinkGeo.MapSuite.Core.FeatureLayer –>
showSelectedFeaturesMode DbfViewerShowSelectedFeaturesMode<!– ThinkGeo.MapSuite.GisEditor.DbfViewerShowSelectedFeaturesMode –>
editMode DbfViewerEditMode<!– ThinkGeo.MapSuite.GisEditor.DbfViewerEditMode –>
dockingMode DbfViewerDockingMode<!– ThinkGeo.MapSuite.GisEditor.DbfViewerDockingMode –>
String<!– System.String –>
SavedConditions
<!– static –>
Return Type
ObservableCollection<QueryConditionViewModel><!– System.Collections.ObjectModel.ObservableCollection{ThinkGeo.MapSuite.GisEditor.QueryConditionViewModel} –>
thinkgeo.mapsuite.giseditor.dataviewerhelper.txt · Last modified: 2017/03/16 21:59 (external edit)
