thinkgeo.mapsuite.giseditor.projectionselectionviewmodel
ThinkGeo.MapSuite.GisEditor.ProjectionSelectionViewModel
<!– Class –>
*System.Object GalaSoft.MvvmLight.ObservableObject *GalaSoft.MvvmLight.ViewModelBase ThinkGeo.MapSuite.GisEditor.ProjectionSelectionViewModel
Public MethodProjectionSelectionViewModel String, String
Public MethodCleanup ViewModelBase
Public MethodGetType Object
Public MethodToString Object
Public MethodVerifyPropertyName String ObservableObject
Protected MethodBroadcast T, T, String ViewModelBase
Protected MethodRaisePropertyChanged String ObservableObject
Protected MethodRaisePropertyChanged Expression<Func<T», T, T, Boolean ViewModelBase
Protected MethodRaisePropertyChanged String, T, T, Boolean ViewModelBase
Protected MethodRaisePropertyChanged Expression<Func<T» ObservableObject
Protected MethodSet String, ref T, T, Boolean ViewModelBase
Protected MethodSet Expression<Func<T», ref T, T ObservableObject
Protected MethodSet String, ref T, T ObservableObject
Protected MethodSet Expression<Func<T», ref T, T, Boolean ViewModelBase
Public PropertyApplyForAll Boolean
Public PropertyCancelCommand RelayCommand
Public PropertyCheckBoxContent String
Public PropertyCheckBoxVisibility Visibility
Public PropertyIsInDesignMode Boolean ViewModelBase
Public PropertyIsReadOnly Boolean
Public PropertyOkCommand ObservedCommand
Public PropertySelectedProj4Parameter String
Public PropertyTextContent String
Public PropertyTextVisibility Visibility
Protected PropertyMessengerInstance IMessenger ViewModelBase
Protected PropertyPropertyChangedHandler PropertyChangedEventHandler ObservableObject
Public EventPropertyChanged PropertyChangedEventArgs ObservableObject
ProjectionSelectionViewModel(String, String)
Name Type Description
textContent String<!– System.String –>
checkBoxContent String<!– System.String –>
Go Back
Cleanup()
Return Type Description
Void<!– System.Void –>
<!– GalaSoft.MvvmLight.ViewModelBase –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
VerifyPropertyName(String)
propertyName String<!– System.String –>
<!– GalaSoft.MvvmLight.ObservableObject –> Go Back
Broadcast(T, T, String)
oldValue T<!– T –>
newValue T<!– T –>
RaisePropertyChanged(String)
RaisePropertyChanged(Expression<Func<T>>, T, T, Boolean)
propertyExpression Expression<Func<T»<!– Expression{Func{T}} –>
oldValue T<!– T –>
newValue T<!– T –>
broadcast Boolean<!– System.Boolean –>
RaisePropertyChanged(String, T, T, Boolean)
oldValue T<!– T –>
newValue T<!– T –>
RaisePropertyChanged(Expression<Func<T>>)
Set(String, ref T, T, Boolean)
field ref T<!– T –>
newValue T<!– T –>
Set(Expression<Func<T>>, ref T, T)
field ref T<!– T –>
newValue T<!– T –>
Set(String, ref T, T)
field ref T<!– T –>
newValue T<!– T –>
Set(Expression<Func<T>>, ref T, T, Boolean)
field ref T<!– T –>
newValue T<!– T –>
ApplyForAll
Return Type
<!– ThinkGeo.MapSuite.GisEditor.ProjectionSelectionViewModel –> Go Back
CancelCommand
Return Type
RelayCommand<!– GalaSoft.MvvmLight.Command.RelayCommand –>
CheckBoxContent
Return Type
CheckBoxVisibility
Return Type
Visibility<!– System.Windows.Visibility –>
IsInDesignMode
Return Type
IsReadOnly
Return Type
OkCommand
Return Type
ObservedCommand<!– ThinkGeo.MapSuite.GisEditor.ObservedCommand –>
Return Type
TextContent
Return Type
TextVisibility
Return Type
MessengerInstance
Return Type
IMessenger<!– GalaSoft.MvvmLight.Messaging.IMessenger –>
Return Type
PropertyChangedEventHandler<!– System.ComponentModel.PropertyChangedEventHandler –>
PropertyChanged
Event Arguments
Event Arguments
PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –>
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
thinkgeo.mapsuite.giseditor.projectionselectionviewmodel.txt · Last modified: 2017/03/16 21:59 (external edit)
