thinkgeo.mapsuite.giseditor.datarepositoryplugin
ThinkGeo.MapSuite.GisEditor.DataRepositoryPlugin
<!– Class –> This plugin is the base class of all data repository plugins. GisEditor collects those plugins to create the data repository tree.
Protected MethodDataRepositoryPlugin
Public MethodApplySettings StorableSettings Plugin Applies the settings to this plugin.
Public MethodCreateDataRepositoryItem Gets the data repository item of data repository plugin.
Public MethodDropOnMap IEnumerable<DataRepositoryItem>
Public MethodGetSettings Plugin Gets plugin settings to save.
Public MethodGetSettingsUI Plugin Gets an UI that configures settings.
Public MethodGetType Object
Public MethodLoad Plugin This method raises when load this plugin.
Public MethodToString Object
Public MethodUnload Plugin This method raises when unload this plugin.
Protected MethodApplySettingsCore StorableSettings Plugin Applies the settings to this plugin.
Protected MethodCreateDataRepositoryItemCore Gets the root data repository item of data repository plugin. This is the core method of GetDataRepositoryItem() to override.
Protected MethodDropOnMapCore IEnumerable<DataRepositoryItem>
Protected MethodGetSettingsCore Plugin Gets plugin settings to save.
Protected MethodGetSettingsUICore Plugin Gets an UI that configures settings.
Protected MethodLoadCore Plugin This method raises when load this plugin.
Protected MethodUnloadCore Plugin This method raises when unload this plugin.
Public PropertyAuthor String Plugin Gets or sets author information for plugin.
Public PropertyCanDropOnMap Boolean
Public PropertyCanRefreshDynamically Boolean
Public PropertyContent UserControl Gets or sets the content of data repository plugin.
Public PropertyContextMenu ContextMenu Gets or sets the context menu of data repository plugin.
Public PropertyDescription String Plugin Gets or sets description for plugin.
Public PropertyId String Plugin Gets the identify of plugin.
Public PropertyIndex Int32 Plugin Gets or sets the index of the plugin.
Public PropertyIsActive Boolean Plugin Gets or sets a value indicating whether this plugin is active.
Public PropertyIsRequired Boolean Plugin Gets or sets a value indicating whether this plugin is required.
Public PropertyLargeIcon ImageSource Plugin Gets or sets large icon for plugin.
Public PropertyName String Plugin Gets or sets the name of plugin.
Public PropertyRootDataRepositoryItem DataRepositoryItem
Public PropertySmallIcon ImageSource Plugin Gets or sets small icon path for plugin.
Protected PropertyCanDropOnMapCore Boolean
Protected PropertyRootDataRepositoryItemCore DataRepositoryItem
DataRepositoryPlugin()
Name Type Description
Go Back
ApplySettings(StorableSettings)
Return Type Description
Void<!– System.Void –>
settings StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> The settings to be applied to this plugin.
<!– ThinkGeo.MapSuite.GisEditor.Plugin –> Go Back
CreateDataRepositoryItem()
DataRepositoryItem<!– ThinkGeo.MapSuite.GisEditor.DataRepositoryItem –> Data repository item.
<!– ThinkGeo.MapSuite.GisEditor.DataRepositoryPlugin –> Go Back
DropOnMap(IEnumerable<DataRepositoryItem>)
dataRepositoryItems IEnumerable<DataRepositoryItem><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.GisEditor.DataRepositoryItem} –>
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetSettings()
StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> Plugin's settings to save.
GetSettingsUI()
SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> A SettingUserControl that configures settings.
Type<!– System.Type –>
Load()
String<!– System.String –>
Unload()
ApplySettingsCore(StorableSettings)
CreateDataRepositoryItemCore()
DataRepositoryItem<!– ThinkGeo.MapSuite.GisEditor.DataRepositoryItem –> Root data repository item.
DropOnMapCore(IEnumerable<DataRepositoryItem>)
GetSettingsCore()
GetSettingsUICore()
LoadCore()
UnloadCore()
Author
Return Type
CanDropOnMap
Return Type
Return Type
Content
Return Type
UserControl<!– System.Windows.Controls.UserControl –>
ContextMenu
Return Type
ContextMenu<!– System.Windows.Controls.ContextMenu –>
Description
Return Type
Id
Return Type
Index
Plugins are orded by this property.
Return Type
IsActive
Return Type
IsRequired
Return Type
LargeIcon
Setting relative path to this property to discover image. Path should be like the form of FolderName(optional)/ImageFullName, such as “Images/NewContent.png” or “Content.png”. Make sure that image you supplied compiling with Build Action Resource.
Return Type
ImageSource<!– System.Windows.Media.ImageSource –>
Return Type
Return Type
SmallIcon
Return Type
CanDropOnMapCore
Return Type
Return Type
thinkgeo.mapsuite.giseditor.datarepositoryplugin.txt · Last modified: 2017/03/16 21:59 (external edit)
