<!– Class –> This class represents a data repository item.
The instance of this object is used to create a hierarchy object to represent the base map list, data folder etc.
*System.Object GalaSoft.MvvmLight.ObservableObject *GalaSoft.MvvmLight.ViewModelBase ThinkGeo.MapSuite.GisEditor.DataRepositoryItem
DataRepositoryItem | Initializes a new instance of the class. |
Cleanup | ViewModelBase | ||
GetRootDataRepositoryItem | |||
GetSearchResult | IEnumerable<String> | Gets the search result from its children tree. | |
Load | Loads current data repository onto active map. | ||
Refresh | |||
Rename | String | ||
ToString | Object | ||
VerifyPropertyName | String | ObservableObject |
Broadcast | T, T, String | ViewModelBase | |
GetSearchResultCore | IEnumerable<String> | ||
LoadCore | Loads current data repository onto active map. | ||
MemberwiseClone | Object | ||
OnLoaded | LoadedDataRepositoryItemEventArgs | ||
OnLoading | LoadingDataRepositoryItemEventArgs | ||
OnRefreshed | EventArgs | ||
OnRefreshing | CancelEventArgs | ||
RaisePropertyChanged | Expression<Func<T» | ObservableObject | |
RaisePropertyChanged | String, T, T, Boolean | ViewModelBase | |
RaisePropertyChanged | Expression<Func<T», T, T, Boolean | ViewModelBase | |
RaisePropertyChanged | String | ObservableObject | |
RefreshCore | |||
RenameCore | String | ||
Set | Expression<Func<T», ref T, T | ObservableObject | |
Set | String, ref T, T, Boolean | ViewModelBase | |
Set | Expression<Func<T», ref T, T, Boolean | ViewModelBase | |
Set | String, ref T, T | ObservableObject |
CanRemove | Boolean | ||
CanRename | Boolean | ||
Category | String | ||
Children | ObservableCollection<DataRepositoryItem> | Gets the children of this data repository item. | |
Content | UserControl | ||
ContextMenu | ContextMenu | Gets or sets the context menu of data repository item instance. | |
CustomData | Dictionary<String,Object> | ||
Icon | ImageSource | Gets or sets the icon of data repository item instance. | |
Id | String | ||
IsExpanded | Boolean | ||
IsInDesignMode | Boolean | ViewModelBase | |
IsLeaf | Boolean | ||
IsLoadable | Boolean | Gets a value indicating whether this instance is allow to load onto the map. | |
IsRenaming | Boolean | ||
IsSelected | Boolean | ||
Name | String | Gets or sets the name of data repository item instance. | |
Parent | DataRepositoryItem | ||
SourcePlugin | DataRepositoryPlugin |
CanRemoveCore | Boolean | ||
CanRenameCore | Boolean | ||
CategoryCore | String | ||
IdCore | String | ||
IsLeafCore | Boolean | ||
IsLoadableCore | Boolean | Gets a value indicating whether this instance is allow to load onto the map. | |
MessengerInstance | IMessenger | ViewModelBase | |
PropertyChangedHandler | PropertyChangedEventHandler | ObservableObject |
PropertyChanged | PropertyChangedEventArgs | ObservableObject | |
<!– GalaSoft.MvvmLight.ViewModelBase –> Go Back
| DataRepositoryItem<!– ThinkGeo.MapSuite.GisEditor.DataRepositoryItem –> |
<!– ThinkGeo.MapSuite.GisEditor.DataRepositoryItem –> Go Back
| Collection<DataRepositoryItem><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.GisEditor.DataRepositoryItem} –> | A set of data repository that matches the keywords. |
| keywords | IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> | The keywords. |
| newName | String<!– System.String –> |
| propertyName | String<!– System.String –> |
<!– GalaSoft.MvvmLight.ObservableObject –> Go Back
| oldValue | T<!– T –> | |
| newValue | T<!– T –> | |
| e | LoadedDataRepositoryItemEventArgs<!– ThinkGeo.MapSuite.GisEditor.LoadedDataRepositoryItemEventArgs –> |
| e | LoadingDataRepositoryItemEventArgs<!– ThinkGeo.MapSuite.GisEditor.LoadingDataRepositoryItemEventArgs –> |
| e | EventArgs<!– System.EventArgs –> |
| e | CancelEventArgs<!– System.ComponentModel.CancelEventArgs –> |
| propertyExpression | Expression<Func<T»<!– Expression{Func{T}} –> |
| propertyName | String<!– System.String –> | |
| broadcast | Boolean<!– System.Boolean –> |
| propertyExpression | Expression<Func<T»<!– Expression{Func{T}} –> | |
| field | ref T<!– T –> | |
| ObservableCollection<DataRepositoryItem><!– System.Collections.ObjectModel.ObservableCollection{ThinkGeo.MapSuite.GisEditor.DataRepositoryItem} –> |
| UserControl<!– System.Windows.Controls.UserControl –> |
| ContextMenu<!– System.Windows.Controls.ContextMenu –> |
| Dictionary<String,Object><!– System.Collections.Generic.Dictionary{System.String,System.Object} –> |
| ImageSource<!– System.Windows.Media.ImageSource –> |
| DataRepositoryPlugin<!– ThinkGeo.MapSuite.GisEditor.DataRepositoryPlugin –> |
| IMessenger<!– GalaSoft.MvvmLight.Messaging.IMessenger –> |
| PropertyChangedEventHandler<!– System.ComponentModel.PropertyChangedEventHandler –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –> |
| Event Arguments |
| Event Arguments |
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
