thinkgeo.mapsuite.wpfdesktopedition
ThinkGeo.MapSuite.WpfDesktopEdition
WpfDesktopEdition
Classes
A B C D E F G I K L M O P S T U V W Z
A
  • AdornmentOverlay
    This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
B
  • BackgroundOverlay
    This class inherits from the Overlay abstract class. The specified overlay specifies the background information of the MapControl.
  • BingMapsOverlay
    This class represents an overlay that requesting from Bing Maps Imagery Metadata Service.
  • BingMapsTileOverlay
    This class represents an overlay that requesting from Bing Maps Imagery Service.
C
D
E
  • EditInteractiveOverlay
  • ExtentInteractiveOverlay
    This class inherits from InterativeOverlay abstract class. This specified overlay describle the Extent Changing interative process with MapControl using Mouse or Keyborad.
F
G
I
  • InMemoryMarkerOverlay
    Represents a MarkerOverlay object that dynamically creates markers from the InMemory features.
  • InteractionArguments
    This class encapsulates the information and simple method for interative actions.
  • InteractiveOverlay
    This class inherits from Overlay abstract class. This specified overlay describle the interative process with MapControl using Mouse or Keyborad.
  • InteractiveResult
    This class specifies the InterativeResult when deal with the Interative method in InterativeOverlay.
K
L
  • LayerOverlay
    This class represents a group of layers; each layer can be of any layer type.
  • LayerTile
    This class represents a Tile that formed with a Layer collection.
  • LogoMapTool
    This class represents an logo tool displays on the bottom right on the map.
M
O
P
S
T
U
  • UriTile
    Represents a tile for requesting from an Uri.
V
W
  • WmsOverlay
    Represents an overlay object that gets map images from the WMS server you specify.
  • WmtsTiledOverlay
    Represents an overlay object that gets map images from the WMTS server you specify.
  • WorldMapKitWmsWpfOverlay
    This class represents an WmsOverlay which has MapSuite world map kit server integrated.
  • WpfGeoCanvas
    This class represents a GeoCanvas to draw by Wpf Shape objects.
  • WpfGeoImage
    This class represents an GeoImage object for WPF. It maintains an Uri and Stream for the image source.
  • WpfMap
    This class represents the map control.
Z
Structures
Enums
C D E I L M O P R T Z
C
  • ControlPointType
    This enumeration specified the control point type when editing a shape. The deafault value is None
D
  • DisplayZoomBarText
    This enum indicates whether a zoom bar text is displayed when dragging the slider.
E
  • ExtentChangedType
    This enumeration specifies the type of extent change that has occurred when doing interactive actions with InterativeOverlay.
I
  • InteractiveOverlayDrawType
    This enumeration specifies the mode to draw the InterativeOverlay when doing interactive actions with InterativeOverlay.
L
  • LockLayerMode
    This enum represents the lock mode while drawing layers.
M
  • MapDoubleLeftClickMode
    This enumeration specifies the behavior that occurs when double-left-clicking on the MapControl. The default value is ZoomIn.
  • MapDoubleRightClickMode
    This enumeration specifies the behavior that occurs when double-right-clicking on the MapControl. The default value is ZoomOut.
  • MapLeftClickDragMode
    This enumeration specifies the behavior that occurs when you left-click-and-drag on the MapControl. The default value is ZoomInWithKey.
  • MapMouseButton
    This enumeration defines a MouseButton for MapControl.
  • MapMouseWheelMode
    This enumeration specifies the behavior that occurs when the mouse wheel is scrolled. The default value is Zooming.
  • MapPanMode
    This enumeration specifies the behavior type for panning. The default value is StandardPanning.
  • MapRightClickDragMode
    This enumeration specifies the behavior that occurs when you right-click-and-drag on the MapControl. The default value is ZoomOutWithKey.
  • MarkerDragMode
    This enumeration specifies how the map markers can be dragged.
  • MouseCoordinateType
    This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
O
P
R
  • RenderMode
    This enumeration represents the drawing mode for rendering map.
T
  • TileType
    This enum represents the tile type in the tile overlay.
  • TrackMode
    TrackMode enumeration sets how the map will react to user interaction.
  • TransitionEffect
    This enumeration specifies the type of transition effect to use when the map is panned or zoomed.
Z
Interfaces
thinkgeo.mapsuite.wpfdesktopedition.1442818192.txt.gz · Last modified: 2015/09/21 06:49 (external edit)
