thinkgeo.mapsuite.wpfdesktopedition.currentscalechangedwpfmapeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs
Provides data for the CurrentScaleChanged event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs
CurrentScaleChangedWpfMapEventArgs()
Initialize an instance of the CurrentScaleChangedEventArgs class.
CurrentScaleChangedWpfMapEventArgs(RectangleShape,Double,GeographyUnit,Single,Single)
Initialize an instance of the CurrentScaleChangedEventArgs class by passing the currentScale, mapUnit and mapWidth.
  • currentExtent
    • Description:A RectangleShape indicates current map extent.
  • currentScale
    • Description:A double value indicates current map scale.
  • mapUnit
    • Description:A GeographyUnit value indicates current map unit.
  • mapWidth
    • Type:Single
    • Description:A float value indicates current map screen width.
  • mapHeight
    • Type:Single
    • Description:A float value indicates current map screen height.
CurrentScale
This property specifies the CurrentScale of the CurrentScaleChangedEventArgs.
MapUnit
This property specifies the MapUnit of the CurrentScaleChangedEventArgs.
MapWidth
This property specifies the MapWidth of the CurrentScaleChangedEventArgs.
  • Type:Single
MapHeight
This property specifies the MapHeight of the CurrentExtentChangedEventArgs.
  • Type:Single
CurrentExtent
This property specifies the CurrentExtent of the CurrentExtentChangedEventArgs.
thinkgeo.mapsuite.wpfdesktopedition.currentscalechangedwpfmapeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
