thinkgeo.mapsuite.wpfdesktopedition.mappanmode
ThinkGeo.MapSuite.WpfDesktopEdition.MapPanMode
This enumeration specifies the behavior type for panning. The default value is StandardPanning.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapPanMode
Items
Default
  • Summary:Default value (StandardPanning) of the enumeration.
StandardPanning
  • Summary:This enumeration item means that the map will behave as standard with respect to panning.
Disabled
  • Summary:This enumeration item means that panning will be disabled.
thinkgeo.mapsuite.wpfdesktopedition.mappanmode.txt · Last modified: 2017/03/16 21:59 (external edit)
