thinkgeo.mapsuite.wpfdesktopedition.panzoombarmaptool
ThinkGeo.MapSuite.WpfDesktopEdition.PanZoomBarMapTool
Represents the panning and zooming panel in the upper left corner of the map.
    • System.Windows.Threading.DispatcherObject
      • System.Windows.DependencyObject
        • System.Windows.Media.Visual
          • System.Windows.UIElement
            • System.Windows.FrameworkElement
              • System.Windows.Controls.Control
                • ThinkGeo.MapSuite.WpfDesktopEdition.MapTool
                  • ThinkGeo.MapSuite.WpfDesktopEdition.PanZoomBarMapTool
PanZoomBarMapTool()
Constructor of PanZoomBarMapTool class.
OnApplyTemplate()
Applys the template of the PanZoomBarMapTool class.
Initialize(WpfMap)
  • wpfMap
ShouldSerializeStyle()
ApplyTemplate()
BeginStoryboard(Storyboard)
  • storyboard
    • Type:Storyboard
BeginStoryboard(Storyboard,HandoffBehavior)
  • storyboard
    • Type:Storyboard
  • handoffBehavior
    • Type:HandoffBehavior
BeginStoryboard(Storyboard,HandoffBehavior,Boolean)
  • storyboard
    • Type:Storyboard
  • handoffBehavior
  • isControllable
ShouldSerializeTriggers()
ShouldSerializeResources()
FindResource(Object)
  • resourceKey
TryFindResource(Object)
  • resourceKey
SetResourceReference(DependencyProperty,Object)
  • dp
    • Type:DependencyProperty
  • name
GetBindingExpression(DependencyProperty)
  • Type:BindingExpression
  • dp
SetBinding(DependencyProperty,BindingBase)
  • Type:BindingExpressionBase
  • dp
  • binding
    • Type:BindingBase
SetBinding(DependencyProperty,String)
  • dp
  • path
BringIntoView()
BringIntoView(Rect)
  • targetRectangle
    • Type:Rect
MoveFocus(TraversalRequest)
  • request
    • Type:TraversalRequest
PredictFocus(FocusNavigationDirection)
  • Type:DependencyObject
  • direction
    • Type:FocusNavigationDirection
BeginInit()
EndInit()
RegisterName(String,Object)
  • name
  • scopedElement
UnregisterName(String)
  • name
FindName(String)
  • name
UpdateDefaultStyle()
ApplyAnimationClock(DependencyProperty,AnimationClock)
  • dp
  • clock
    • Type:AnimationClock
ApplyAnimationClock(DependencyProperty,AnimationClock,HandoffBehavior)
  • dp
  • clock
  • handoffBehavior
BeginAnimation(DependencyProperty,AnimationTimeline)
  • dp
  • animation
    • Type:AnimationTimeline
BeginAnimation(DependencyProperty,AnimationTimeline,HandoffBehavior)
  • dp
  • animation
  • handoffBehavior
GetAnimationBaseValue(DependencyProperty)
  • dp
ShouldSerializeInputBindings()
ShouldSerializeCommandBindings()
RaiseEvent(RoutedEventArgs)
  • e
    • Type:RoutedEventArgs
AddHandler(RoutedEvent,Delegate)
  • routedEvent
    • Type:RoutedEvent
  • handler
    • Type:Delegate
AddHandler(RoutedEvent,Delegate,Boolean)
  • routedEvent
    • Type:RoutedEvent
  • handler
    • Type:Delegate
  • handledEventsToo
RemoveHandler(RoutedEvent,Delegate)
  • routedEvent
    • Type:RoutedEvent
  • handler
    • Type:Delegate
AddToEventRoute(EventRoute,RoutedEventArgs)
  • route
    • Type:EventRoute
  • e
InvalidateMeasure()
InvalidateArrange()
InvalidateVisual()
Measure(Size)
  • availableSize
    • Type:Size
Arrange(Rect)
  • finalRect
    • Type:Rect
UpdateLayout()
TranslatePoint(Point,UIElement)
  • Type:Point
  • point
    • Type:Point
  • relativeTo
    • Type:UIElement
InputHitTest(Point)
  • Type:IInputElement
  • point
    • Type:Point
CaptureMouse()
ReleaseMouseCapture()
CaptureStylus()
ReleaseStylusCapture()
Focus()
CaptureTouch(TouchDevice)
  • touchDevice
    • Type:TouchDevice
ReleaseTouchCapture(TouchDevice)
  • touchDevice
    • Type:TouchDevice
ReleaseAllTouchCaptures()
IsAncestorOf(DependencyObject)
  • descendant
IsDescendantOf(DependencyObject)
  • ancestor
FindCommonVisualAncestor(DependencyObject)
  • otherVisual
TransformToAncestor(Visual)
  • Type:GeneralTransform
  • ancestor
    • Type:Visual
TransformToAncestor(Visual3D)
  • Type:GeneralTransform2DTo3D
  • ancestor
    • Type:Visual3D
TransformToDescendant(Visual)
  • descendant
    • Type:Visual
TransformToVisual(Visual)
  • visual
    • Type:Visual
PointToScreen(Point)
  • Type:Point
  • point
    • Type:Point
PointFromScreen(Point)
  • Type:Point
  • point
    • Type:Point
GetValue(DependencyProperty)
  • dp
SetValue(DependencyProperty,Object)
  • dp
  • value
SetCurrentValue(DependencyProperty,Object)
  • dp
  • value
SetValue(DependencyPropertyKey,Object)
  • key
    • Type:DependencyPropertyKey
  • value
ClearValue(DependencyProperty)
  • dp
ClearValue(DependencyPropertyKey)
  • key
CoerceValue(DependencyProperty)
  • dp
InvalidateProperty(DependencyProperty)
  • dp
ReadLocalValue(DependencyProperty)
  • dp
GetLocalValueEnumerator()
  • Type:LocalValueEnumerator
CheckAccess()
VerifyAccess()
OnGlobeButtonClick(RectangleShape)
Called when clicking globe button.
EnabledChangedCore(Boolean)
Occurs when the IsEnable property is changed.
  • newValue
    • Description:Whether the tool is enabled or not.
InitializeCore(WpfMap)
  • wpfMap
OnTemplateChangedInternal(FrameworkTemplate,FrameworkTemplate)
  • oldTemplate
    • Type:FrameworkTemplate
  • newTemplate
OnTemplateChanged(ControlTemplate,ControlTemplate)
  • oldTemplate
    • Type:ControlTemplate
  • newTemplate
OnPreviewMouseDoubleClick(MouseButtonEventArgs)
  • e
    • Type:MouseButtonEventArgs
OnMouseDoubleClick(MouseButtonEventArgs)
  • e
OnPreApplyTemplate()
OnPostApplyTemplate()
UpdateVisualState()
UpdateVisualState(Boolean)
  • useTransitions
ChangeVisualState(Boolean)
  • useTransitions
ChangeValidationVisualState(Boolean)
  • useTransitions
MeasureOverride(Size)
  • Type:Size
  • constraint
    • Type:Size
ArrangeOverride(Size)
  • Type:Size
  • arrangeBounds
    • Type:Size
ReadControlFlag(ControlBoolFlags)
  • reqFlag
    • Type:ControlBoolFlags
WriteControlFlag(ControlBoolFlags,Boolean)
  • reqFlag
  • set
OnStyleChanged(Style,Style)
  • oldStyle
    • Type:Style
  • newStyle
    • Type:Style
ParentLayoutInvalidated(UIElement)
  • child
    • Type:UIElement
GetVisualChild(Int32)
  • Type:Visual
  • index
GetTemplateChild(String)
  • childName
HasNonDefaultValue(DependencyProperty)
  • dp
EvaluateBaseValueCore(DependencyProperty,PropertyMetadata,EffectiveValueEntry&)
  • dp
  • metadata
    • Type:PropertyMetadata
  • newEntry
    • Type:EffectiveValueEntry&
GetRawValue(DependencyProperty,PropertyMetadata,EffectiveValueEntry&)
  • dp
  • metadata
  • entry
GetExpressionCore(DependencyProperty,PropertyMetadata)
  • Type:Expression
  • dp
  • metadata
OnPropertyChanged(DependencyPropertyChangedEventArgs)
  • e
    • Type:DependencyPropertyChangedEventArgs
GetPlainText()
pushTextRenderingMode()
OnAncestorChanged()
OnVisualParentChanged(DependencyObject)
  • oldParent
OnVisualAncestorChanged(Object,AncestorChangedEventArgs)
  • sender
  • e
    • Type:AncestorChangedEventArgs
GetUIParentCore()
AdjustEventSource(RoutedEventArgs)
  • args
AdjustBranchSource(RoutedEventArgs)
  • args
BuildRouteCore(EventRoute,RoutedEventArgs)
  • route
    • Type:EventRoute
  • args
BuildRouteCoreHelper(EventRoute,RoutedEventArgs,Boolean)
  • route
    • Type:EventRoute
  • args
  • shouldAddIntermediateElementsToRoute
AddToEventRouteCore(EventRoute,RoutedEventArgs)
  • route
    • Type:EventRoute
  • args
IgnoreModelParentBuildRoute(RoutedEventArgs)
  • args
InvalidateAutomationAncestorsCore(Stack<DependencyObject>,Boolean&)
  • branchNodeStack
    • Type:Stack<DependencyObject>
  • continuePastCoreTree
    • Type:Boolean&
InvalidateAutomationAncestorsCoreHelper(Stack<DependencyObject>,Boolean&,Boolean)
  • branchNodeStack
    • Type:Boolean&
  • shouldInvalidateIntermediateElements
MeasureCore(Size)
  • Type:Size
  • availableSize
    • Type:Size
ArrangeCore(Rect)
  • finalRect
    • Type:Rect
OnRenderSizeChanged(SizeChangedInfo)
  • sizeInfo
    • Type:SizeChangedInfo
GetLayoutClip(Size)
  • Type:Geometry
  • layoutSlotSize
    • Type:Size
GetLayoutClipInternal()
  • Type:Geometry
OnGotFocus(RoutedEventArgs)
  • e
OnInitialized(EventArgs)
  • e
    • Type:EventArgs
OnPresentationSourceChanged(Boolean)
  • attached
OnAddHandler(RoutedEvent,Delegate)
  • routedEvent
    • Type:RoutedEvent
  • handler
    • Type:Delegate
OnRemoveHandler(RoutedEvent,Delegate)
  • routedEvent
    • Type:RoutedEvent
  • handler
    • Type:Delegate
OnLoaded(RoutedEventArgs)
  • args
OnUnloaded(RoutedEventArgs)
  • args
AddSynchronizedInputPreOpportunityHandlerCore(EventRoute,RoutedEventArgs)
  • route
    • Type:EventRoute
  • args
RaiseClrEvent(EventPrivateKey,EventArgs)
  • key
    • Type:EventPrivateKey
  • args
    • Type:EventArgs
OnToolTipOpening(ToolTipEventArgs)
  • e
    • Type:ToolTipEventArgs
OnToolTipClosing(ToolTipEventArgs)
  • e
OnContextMenuOpening(ContextMenuEventArgs)
  • e
    • Type:ContextMenuEventArgs
OnContextMenuClosing(ContextMenuEventArgs)
  • e
EventHandlersStoreAdd(EventPrivateKey,Delegate)
  • key
  • handler
    • Type:Delegate
EventHandlersStoreRemove(EventPrivateKey,Delegate)
  • key
  • handler
    • Type:Delegate
ReadInternalFlag(InternalFlags)
  • reqFlag
    • Type:InternalFlags
ReadInternalFlag2(InternalFlags2)
  • reqFlag
    • Type:InternalFlags2
WriteInternalFlag(InternalFlags,Boolean)
  • reqFlag
  • set
WriteInternalFlag2(InternalFlags2,Boolean)
  • reqFlag
  • set
FindName(String,DependencyObject&)
  • name
  • scopeOwner
    • Type:DependencyObject&
FindResourceOnSelf(Object,Boolean,Boolean)
  • resourceKey
  • allowDeferredResourceReference
  • mustReturnDeferredResourceReference
ContextVerifiedGetParent()
AddLogicalChild(Object)
  • child
RemoveLogicalChild(Object)
  • child
ChangeLogicalParent(DependencyObject)
  • newParent
OnNewParent(DependencyObject)
  • newParent
OnAncestorChangedInternal(TreeChangeInfo)
  • parentTreeState
    • Type:TreeChangeInfo
InvalidateTreeDependentProperties(TreeChangeInfo,Boolean)
  • Type:FrugalObjectList<DependencyProperty>
  • parentTreeState
  • isSelfInheritanceParent
UpdateStyleProperty()
UpdateThemeStyleProperty()
OnThemeChanged()
FireLoadedOnDescendentsInternal()
FireUnloadedOnDescendentsInternal()
ShouldProvideInheritanceContext(DependencyObject,DependencyProperty)
  • target
  • property
AddInheritanceContext(DependencyObject,DependencyProperty)
  • context
  • property
RemoveInheritanceContext(DependencyObject,DependencyProperty)
  • context
  • property
OnInheritanceContextChangedCore(EventArgs)
  • args
    • Type:EventArgs
ChangeSubtreeHasLoadedChangedHandler(DependencyObject)
  • mentor
RaiseInheritedPropertyChangedEvent(InheritablePropertyChangeInfo&)
  • info
    • Type:InheritablePropertyChangeInfo&
EvaluateAnimatedValueCore(DependencyProperty,PropertyMetadata,EffectiveValueEntry&)
  • dp
  • metadata
  • entry
BuildRoute(EventRoute,RoutedEventArgs)
  • route
    • Type:EventRoute
  • args
RaiseEvent(RoutedEventArgs,Boolean)
  • args
  • trusted
RaiseTrustedEvent(RoutedEventArgs)
  • args
EnsureEventHandlersStore()
OnPreviewMouseDown(MouseButtonEventArgs)
  • e
OnMouseDown(MouseButtonEventArgs)
  • e
OnPreviewMouseUp(MouseButtonEventArgs)
  • e
OnMouseUp(MouseButtonEventArgs)
  • e
OnPreviewMouseLeftButtonDown(MouseButtonEventArgs)
  • e
OnMouseLeftButtonDown(MouseButtonEventArgs)
  • e
OnPreviewMouseLeftButtonUp(MouseButtonEventArgs)
  • e
OnMouseLeftButtonUp(MouseButtonEventArgs)
  • e
OnPreviewMouseRightButtonDown(MouseButtonEventArgs)
  • e
OnMouseRightButtonDown(MouseButtonEventArgs)
  • e
OnPreviewMouseRightButtonUp(MouseButtonEventArgs)
  • e
OnMouseRightButtonUp(MouseButtonEventArgs)
  • e
OnPreviewMouseMove(MouseEventArgs)
  • e
    • Type:MouseEventArgs
OnMouseMove(MouseEventArgs)
  • e
OnPreviewMouseWheel(MouseWheelEventArgs)
  • e
    • Type:MouseWheelEventArgs
OnMouseWheel(MouseWheelEventArgs)
  • e
OnMouseEnter(MouseEventArgs)
  • e
OnMouseLeave(MouseEventArgs)
  • e
OnGotMouseCapture(MouseEventArgs)
  • e
OnLostMouseCapture(MouseEventArgs)
  • e
OnQueryCursor(QueryCursorEventArgs)
  • e
    • Type:QueryCursorEventArgs
OnPreviewStylusDown(StylusDownEventArgs)
  • e
    • Type:StylusDownEventArgs
OnStylusDown(StylusDownEventArgs)
  • e
OnPreviewStylusUp(StylusEventArgs)
  • e
    • Type:StylusEventArgs
OnStylusUp(StylusEventArgs)
  • e
OnPreviewStylusMove(StylusEventArgs)
  • e
OnStylusMove(StylusEventArgs)
  • e
OnPreviewStylusInAirMove(StylusEventArgs)
  • e
OnStylusInAirMove(StylusEventArgs)
  • e
OnStylusEnter(StylusEventArgs)
  • e
OnStylusLeave(StylusEventArgs)
  • e
OnPreviewStylusInRange(StylusEventArgs)
  • e
OnStylusInRange(StylusEventArgs)
  • e
OnPreviewStylusOutOfRange(StylusEventArgs)
  • e
OnStylusOutOfRange(StylusEventArgs)
  • e
OnPreviewStylusSystemGesture(StylusSystemGestureEventArgs)
  • e
    • Type:StylusSystemGestureEventArgs
OnStylusSystemGesture(StylusSystemGestureEventArgs)
  • e
OnGotStylusCapture(StylusEventArgs)
  • e
OnLostStylusCapture(StylusEventArgs)
  • e
OnStylusButtonDown(StylusButtonEventArgs)
  • e
    • Type:StylusButtonEventArgs
OnStylusButtonUp(StylusButtonEventArgs)
  • e
OnPreviewStylusButtonDown(StylusButtonEventArgs)
  • e
OnPreviewStylusButtonUp(StylusButtonEventArgs)
  • e
OnPreviewKeyDown(KeyEventArgs)
  • e
    • Type:KeyEventArgs
OnKeyDown(KeyEventArgs)
  • e
    • Type:KeyEventArgs
OnPreviewKeyUp(KeyEventArgs)
  • e
    • Type:KeyEventArgs
OnKeyUp(KeyEventArgs)
  • e
    • Type:KeyEventArgs
OnPreviewGotKeyboardFocus(KeyboardFocusChangedEventArgs)
  • e
    • Type:KeyboardFocusChangedEventArgs
OnGotKeyboardFocus(KeyboardFocusChangedEventArgs)
  • e
OnPreviewLostKeyboardFocus(KeyboardFocusChangedEventArgs)
  • e
OnLostKeyboardFocus(KeyboardFocusChangedEventArgs)
  • e
OnPreviewTextInput(TextCompositionEventArgs)
  • e
    • Type:TextCompositionEventArgs
OnTextInput(TextCompositionEventArgs)
  • e
OnPreviewQueryContinueDrag(QueryContinueDragEventArgs)
  • e
    • Type:QueryContinueDragEventArgs
OnQueryContinueDrag(QueryContinueDragEventArgs)
  • e
OnPreviewGiveFeedback(GiveFeedbackEventArgs)
  • e
    • Type:GiveFeedbackEventArgs
OnGiveFeedback(GiveFeedbackEventArgs)
  • e
OnPreviewDragEnter(DragEventArgs)
  • e
    • Type:DragEventArgs
OnDragEnter(DragEventArgs)
  • e
OnPreviewDragOver(DragEventArgs)
  • e
OnDragOver(DragEventArgs)
  • e
OnPreviewDragLeave(DragEventArgs)
  • e
OnDragLeave(DragEventArgs)
  • e
OnPreviewDrop(DragEventArgs)
  • e
OnDrop(DragEventArgs)
  • e
OnPreviewTouchDown(TouchEventArgs)
  • e
    • Type:TouchEventArgs
OnTouchDown(TouchEventArgs)
  • e
OnPreviewTouchMove(TouchEventArgs)
  • e
OnTouchMove(TouchEventArgs)
  • e
OnPreviewTouchUp(TouchEventArgs)
  • e
OnTouchUp(TouchEventArgs)
  • e
OnGotTouchCapture(TouchEventArgs)
  • e
OnLostTouchCapture(TouchEventArgs)
  • e
OnTouchEnter(TouchEventArgs)
  • e
OnTouchLeave(TouchEventArgs)
  • e
OnIsMouseDirectlyOverChanged(DependencyPropertyChangedEventArgs)
  • e
OnIsKeyboardFocusWithinChanged(DependencyPropertyChangedEventArgs)
  • e
RaiseIsKeyboardFocusWithinChanged(DependencyPropertyChangedEventArgs)
  • args
OnIsMouseCapturedChanged(DependencyPropertyChangedEventArgs)
  • e
OnIsMouseCaptureWithinChanged(DependencyPropertyChangedEventArgs)
  • e
RaiseIsMouseCaptureWithinChanged(DependencyPropertyChangedEventArgs)
  • args
OnIsStylusDirectlyOverChanged(DependencyPropertyChangedEventArgs)
  • e
OnIsStylusCapturedChanged(DependencyPropertyChangedEventArgs)
  • e
OnIsStylusCaptureWithinChanged(DependencyPropertyChangedEventArgs)
  • e
RaiseIsStylusCaptureWithinChanged(DependencyPropertyChangedEventArgs)
  • args
OnIsKeyboardFocusedChanged(DependencyPropertyChangedEventArgs)
  • e
ReadFlag(CoreFlags)
  • field
    • Type:CoreFlags
WriteFlag(CoreFlags,Boolean)
  • field
    • Type:CoreFlags
  • value
InvalidateMeasureInternal()
InvalidateArrangeInternal()
OnChildDesiredSizeChanged(UIElement)
  • child
    • Type:UIElement
GetUIParentOrICH(UIElement&,IContentHost&)
  • uiParent
    • Type:UIElement&
  • ich
    • Type:IContentHost&
GetUIParentWithinLayoutIsland()
  • Type:UIElement
OnRender(DrawingContext)
  • drawingContext
    • Type:DrawingContext
GetHitTestBounds()
  • Type:Rect
  • sender
  • e
GetUIParent()
GetUIParent(Boolean)
  • continuePastVisualTree
GetUIParentNo3DTraversal()
AddSynchronizedInputPreOpportunityHandler(EventRoute,RoutedEventArgs)
  • route
    • Type:EventRoute
  • args
AddSynchronizedInputPostOpportunityHandler(EventRoute,RoutedEventArgs)
  • route
    • Type:EventRoute
  • args
SynchronizedInputPreOpportunityHandler(Object,RoutedEventArgs)
  • sender
  • args
SynchronizedInputPostOpportunityHandler(Object,RoutedEventArgs)
  • sender
  • args
StartListeningSynchronizedInput(SynchronizedInputType)
  • inputType
    • Type:SynchronizedInputType
CancelSynchronizedInput()
InputHitTest(Point,IInputElement&,IInputElement&)
  • pt
    • Type:Point
  • enabledHit
    • Type:IInputElement&
  • rawHit
InputHitTest(Point,IInputElement&,IInputElement&,HitTestResult&)
  • pt
    • Type:Point
  • enabledHit
  • rawHit
  • rawHitResult
    • Type:HitTestResult&
SynchronizeReverseInheritPropertyFlags(DependencyObject,Boolean)
  • oldParent
  • isCoreParent
BlockReverseInheritance()
OnAccessKey(AccessKeyEventArgs)
  • e
    • Type:AccessKeyEventArgs
HitTestCore(PointHitTestParameters)
  • hitTestParameters
    • Type:PointHitTestParameters
HitTestCore(GeometryHitTestParameters)
  • Type:GeometryHitTestResult
  • hitTestParameters
    • Type:GeometryHitTestParameters
RenderOpen()
RenderClose(IDrawingContent)
  • newContent
    • Type:IDrawingContent
FreeContent(Channel)
  • channel
    • Type:Channel
GetContentBounds()
  • Type:Rect
WalkContent(DrawingContextWalker)
  • walker
    • Type:DrawingContextWalker
RenderContent(RenderContext,Boolean)
  • ctx
    • Type:RenderContext
  • isOnChannel
GetDrawing()
  • Type:DrawingGroup
InvokeAccessKey(AccessKeyEventArgs)
  • e
OnLostFocus(RoutedEventArgs)
  • e
UpdateIsVisibleCache()
OnCreateAutomationPeer()
  • Type:AutomationPeer
GetAutomationPeer()
CreateGenericRootAutomationPeer()
SetPersistId(Int32)
  • value
OnManipulationStarting(ManipulationStartingEventArgs)
  • e
    • Type:ManipulationStartingEventArgs
OnManipulationStarted(ManipulationStartedEventArgs)
  • e
    • Type:ManipulationStartedEventArgs
OnManipulationDelta(ManipulationDeltaEventArgs)
  • e
    • Type:ManipulationDeltaEventArgs
OnManipulationInertiaStarting(ManipulationInertiaStartingEventArgs)
  • e
    • Type:ManipulationInertiaStartingEventArgs
OnManipulationBoundaryFeedback(ManipulationBoundaryFeedbackEventArgs)
  • e
    • Type:ManipulationBoundaryFeedbackEventArgs
OnManipulationCompleted(ManipulationCompletedEventArgs)
  • e
    • Type:ManipulationCompletedEventArgs
IsOnChannel(Channel)
  • channel
    • Type:Channel
AddRefOnChannelCore(Channel)
  • Type:ResourceHandle
  • channel
    • Type:Channel
ReleaseOnChannelCore(Channel)
  • channel
    • Type:Channel
CalculateSubgraphBoundsInnerSpace()
  • Type:Rect
CalculateSubgraphRenderBoundsInnerSpace()
  • Type:Rect
CalculateSubgraphBoundsInnerSpace(Boolean)
  • Type:Rect
  • renderBounds
CalculateSubgraphBoundsOuterSpace()
  • Type:Rect
CalculateSubgraphRenderBoundsOuterSpace()
  • Type:Rect
AddRefOnChannelForCyclicBrush(ICyclicBrush,Channel)
  • cyclicBrush
    • Type:ICyclicBrush
  • channel
    • Type:Channel
ReleaseOnChannelForCyclicBrush(ICyclicBrush,Channel)
  • cyclicBrush
    • Type:ICyclicBrush
  • channel
    • Type:Channel
VerifyAPIReadOnly()
VerifyAPIReadOnly(DependencyObject)
  • value
VerifyAPIReadWrite()
VerifyAPIReadWrite(DependencyObject)
  • value
Precompute()
PrecomputeContent()
PrecomputeRecursive(Rect&)
  • bboxSubgraph
    • Type:Rect&
Render(RenderContext,UInt32)
  • ctx
  • childIndex
    • Type:UInt32
RenderRecursive(RenderContext)
  • ctx
Enter()
Exit()
InvalidateHitTestBounds()
HitTest(Point)
  • point
    • Type:Point
HitTest(Point,Boolean)
  • point
    • Type:Point
  • include2DOn3D
HitTest(HitTestFilterCallback,HitTestResultCallback,HitTestParameters)
  • filterCallback
    • Type:HitTestFilterCallback
  • resultCallback
    • Type:HitTestResultCallback
  • hitTestParameters
    • Type:HitTestParameters
HitTestPoint(HitTestFilterCallback,HitTestResultCallback,PointHitTestParameters)
  • Type:HitTestResultBehavior
  • filterCallback
  • resultCallback
  • pointParams
TransformToOuterSpace()
HitTestGeometry(HitTestFilterCallback,HitTestResultCallback,GeometryHitTestParameters)
  • filterCallback
  • resultCallback
  • geometryParams
HitTestPointInternal(HitTestFilterCallback,HitTestResultCallback,PointHitTestParameters)
  • filterCallback
  • resultCallback
  • hitTestParameters
InternalGetVisualChild(Int32)
  • Type:Visual
  • index
InternalGet2DOr3DVisualChild(Int32)
  • index
InternalAddVisualChild(Visual)
  • child
    • Type:Visual
InternalRemoveVisualChild(Visual)
  • child
    • Type:Visual
  • child
    • Type:Visual
  • child
    • Type:Visual
InvalidateZOrder()
InternalSetOffsetWorkaround(Vector)
  • offset
    • Type:Vector
InternalSetTransformWorkaround(Transform)
  • transform
    • Type:Transform
BitmapEffectEmulationChanged(Object,EventArgs)
  • sender
  • e
    • Type:EventArgs
ChangeVisualClip(Geometry,Boolean)
  • newClip
    • Type:Geometry
  • dontSetWhenClose
DisconnectAttachedResource(VisualProxyFlags,IResource)
  • correspondingFlag
    • Type:VisualProxyFlags
  • attachedResource
    • Type:IResource
FireOnVisualParentChanged(DependencyObject)
  • oldParent
OnVisualChildrenChanged(DependencyObject,DependencyObject)
  • visualAdded
  • visualRemoved
SetFlagsToRoot(Boolean,VisualFlags)
  • value
  • flag
    • Type:VisualFlags
FindFirstAncestorWithFlagsAnd(VisualFlags)
  • flag
    • Type:VisualFlags
TrySimpleTransformToAncestor(Visual,Boolean,GeneralTransform&,Matrix&)
  • ancestor
    • Type:Visual
  • inverse
  • generalTransform
    • Type:GeneralTransform&
  • simpleTransform
    • Type:Matrix&
TrySimpleTransformToAncestor(Visual3D,GeneralTransform2DTo3D&)
  • ancestor
    • Type:Visual3D
  • transformTo3D
    • Type:GeneralTransform2DTo3D&
ClipChanged(Object,EventArgs)
  • sender
  • e
    • Type:EventArgs
ScrollableAreaClipChanged(Object,EventArgs)
  • sender
  • e
    • Type:EventArgs
TransformChanged(Object,EventArgs)
  • sender
  • e
    • Type:EventArgs
EffectChanged(Object,EventArgs)
  • sender
  • e
    • Type:EventArgs
CacheModeChanged(Object,EventArgs)
  • sender
  • e
    • Type:EventArgs
GuidelinesChanged(Object,EventArgs)
  • sender
  • e
    • Type:EventArgs
OpacityMaskChanged(Object,EventArgs)
  • sender
  • e
    • Type:EventArgs
ContentsChanged(Object,EventArgs)
  • sender
  • e
    • Type:EventArgs
SetFlagsOnAllChannels(Boolean,VisualProxyFlags)
  • value
  • flagsToChange
SetFlags(Channel,Boolean,VisualProxyFlags)
  • channel
    • Type:Channel
  • value
  • flagsToChange
SetFlags(Boolean,VisualFlags)
  • value
  • flags
    • Type:VisualFlags
CheckFlagsOnAllChannels(VisualProxyFlags)
  • flagsToCheck
CheckFlagsAnd(Channel,VisualProxyFlags)
  • channel
    • Type:Channel
  • flagsToCheck
CheckFlagsAnd(VisualFlags)
  • flags
    • Type:VisualFlags
CheckFlagsOr(Channel,VisualProxyFlags)
  • channel
    • Type:Channel
  • flagsToCheck
CheckFlagsOr(VisualFlags)
  • flags
    • Type:VisualFlags
PropagateChangedFlags()
Seal()
GetValueEntry(EntryIndex,DependencyProperty,PropertyMetadata,RequestFlags)
  • entryIndex
    • Type:EntryIndex
  • dp
  • metadata
  • requests
    • Type:RequestFlags
SetValue(DependencyProperty,Boolean)
  • dp
  • value
SetCurrentValue(DependencyProperty,Boolean)
  • dp
  • value
SetValueInternal(DependencyProperty,Object)
  • dp
  • value
SetCurrentValueInternal(DependencyProperty,Object)
  • dp
  • value
SetDeferredValue(DependencyProperty,DeferredReference)
  • dp
  • deferredReference
    • Type:DeferredReference
SetCurrentDeferredValue(DependencyProperty,DeferredReference)
  • dp
  • deferredReference
SetMutableDefaultValue(DependencyProperty,Object)
  • dp
  • value
SetValue(DependencyPropertyKey,Boolean)
  • dp
  • value
ProvideSelfAsInheritanceContext(Object,DependencyProperty)
  • value
  • dp
ProvideSelfAsInheritanceContext(DependencyObject,DependencyProperty)
  • doValue
  • dp
RemoveSelfAsInheritanceContext(Object,DependencyProperty)
  • value
  • dp
RemoveSelfAsInheritanceContext(DependencyObject,DependencyProperty)
  • doValue
  • dp
ContainsValue(DependencyProperty)
  • dp
InvalidateSubProperty(DependencyProperty)
  • dp
NotifySubPropertyChange(DependencyProperty)
  • dp
InvalidateProperty(DependencyProperty,Boolean)
  • dp
  • preserveCurrentValue
UpdateEffectiveValue(EntryIndex,DependencyProperty,PropertyMetadata,EffectiveValueEntry,EffectiveValueEntry&,Boolean,Boolean,OperationType)
  • Type:UpdateResult
  • entryIndex
    • Type:EntryIndex
  • dp
  • metadata
  • oldEntry
  • newEntry
  • coerceWithDeferredReference
  • coerceWithCurrentValue
  • operationType
    • Type:OperationType
NotifyPropertyChange(DependencyPropertyChangedEventArgs)
  • args
ShouldSerializeProperty(DependencyProperty)
  • dp
GetValueSource(DependencyProperty,PropertyMetadata,Boolean&)
  • Type:BaseValueSourceInternal
  • dp
  • metadata
  • hasModifiers
    • Type:Boolean&
GetValueSource(DependencyProperty,PropertyMetadata,Boolean&,Boolean&,Boolean&,Boolean&,Boolean&)
  • dp
  • metadata
  • hasModifiers
    • Type:Boolean&
  • isExpression
    • Type:Boolean&
  • isAnimated
    • Type:Boolean&
  • isCoerced
    • Type:Boolean&
  • isCurrent
    • Type:Boolean&
ReadLocalValueEntry(EntryIndex,DependencyProperty,Boolean)
  • entryIndex
    • Type:EntryIndex
  • dp
  • allowDeferredReferences
HasAnyExpression()
HasExpression(EntryIndex,DependencyProperty)
  • entryIndex
    • Type:EntryIndex
  • dp
OnInheritanceContextChanged(EventArgs)
  • args
    • Type:EventArgs
Debug_AssertNoInheritanceContextListeners()
BeginPropertyInitialization()
EndPropertyInitialization()
SetIsSelfInheritanceParent()
SynchronizeInheritanceParent(DependencyObject)
  • parent
LookupEntry(Int32)
  • Type:EntryIndex
  • targetIndex
SetEffectiveValue(EntryIndex,DependencyProperty,PropertyMetadata,EffectiveValueEntry,EffectiveValueEntry)
  • entryIndex
    • Type:EntryIndex
  • dp
  • metadata
  • newEntry
  • oldEntry
SetEffectiveValue(EntryIndex,DependencyProperty,Int32,PropertyMetadata,Object,BaseValueSourceInternal)
  • entryIndex
    • Type:EntryIndex
  • dp
  • targetIndex
  • metadata
  • value
  • valueSource
UnsetEffectiveValue(EntryIndex,DependencyProperty,PropertyMetadata)
  • entryIndex
    • Type:EntryIndex
  • dp
  • metadata
DetachFromDispatcher()
DisplayZoomBarText
Gets and sets whether the track level feature is enabled.
If it's none, a small zoom level tip won't appear when dragging the zoom bar up and down. The default value is None.
GlobeButtonVisibility
This property gets
  • Type:Visibility
GlobeButtonImageSource
Gets or sets the image source for the globe button.
  • Type:BitmapSource
Content
CurrentMap
BorderBrush
  • Type:Brush
BorderThickness
  • Type:Thickness
Background
  • Type:Brush
Foreground
  • Type:Brush
FontFamily
  • Type:FontFamily
FontSize
FontStretch
  • Type:FontStretch
FontStyle
  • Type:FontStyle
FontWeight
  • Type:FontWeight
HorizontalContentAlignment
  • Type:HorizontalAlignment
VerticalContentAlignment
  • Type:VerticalAlignment
TabIndex
IsTabStop
Padding
  • Type:Thickness
Template
Style
  • Type:Style
OverridesDefaultStyle
UseLayoutRounding
Triggers
  • Type:TriggerCollection
TemplatedParent
Resources
  • Type:ResourceDictionary
DataContext
BindingGroup
  • Type:BindingGroup
Language
  • Type:XmlLanguage
Tag
InputScope
  • Type:InputScope
ActualWidth
ActualHeight
LayoutTransform
  • Type:Transform
Width
MinWidth
MaxWidth
Height
MinHeight
MaxHeight
FlowDirection
  • Type:FlowDirection
Margin
  • Type:Thickness
HorizontalAlignment
VerticalAlignment
FocusVisualStyle
  • Type:Style
Cursor
  • Type:Cursor
ForceCursor
IsInitialized
IsLoaded
ToolTip
ContextMenu
  • Type:ContextMenu
Parent
HasAnimatedProperties
InputBindings
  • Type:InputBindingCollection
CommandBindings
  • Type:CommandBindingCollection
AllowDrop
DesiredSize
  • Type:Size
IsMeasureValid
IsArrangeValid
RenderSize
  • Type:Size
RenderTransform
  • Type:Transform
RenderTransformOrigin
  • Type:Point
IsMouseDirectlyOver
IsMouseOver
IsStylusOver
IsMouseCaptured
IsStylusCaptured
IsKeyboardFocused
IsInputMethodEnabled
Opacity
OpacityMask
  • Type:Brush
BitmapEffect
  • Type:BitmapEffect
Effect
  • Type:Effect
BitmapEffectInput
  • Type:BitmapEffectInput
CacheMode
  • Type:CacheMode
Uid
Visibility
  • Type:Visibility
ClipToBounds
Clip
  • Type:Geometry
SnapsToDevicePixels
IsFocused
IsEnabled
IsHitTestVisible
IsVisible
Focusable
PersistId
IsManipulationEnabled
AreAnyTouchesOver
AreAnyTouchesDirectlyOver
AreAnyTouchesCapturedWithin
TouchesCaptured
  • Type:IEnumerable<TouchDevice>
TouchesOver
TouchesDirectlyOver
DependencyObjectType
  • Type:DependencyObjectType
IsSealed
Dispatcher
  • Type:Dispatcher
TemplateInternal
TemplateCache
HandlesScrolling
VisualStateChangeSuspended
DefaultStyleKey
ThemeStyle
  • Type:Style
DTypeThemeStyleKey
IsTemplateRoot
TemplateChild
  • Type:UIElement
StateGroupsRoot
  • Type:FrameworkElement
VisualChildrenCount
HasResources
InheritanceBehavior
  • Type:InheritanceBehavior
HasResourceReference
IsLogicalChildrenIterationInProgress
InVisibilityCollapsedTree
SubtreeHasLoadedChangeHandler
IsLoadedCache
IsParentAnFE
IsTemplatedParentAnFE
HasLogicalChildren
IsRightToLeft
TemplateChildIndex
IsRequestingExpression
BypassLayoutPolicies
EffectiveValuesInitialSize
LogicalChildren
  • Type:IEnumerator
ThisHasLoadedChangeEventHandler
HasFefLoadedChangeHandler
InheritanceContext
IsStyleUpdateInProgress
IsThemeStyleUpdateInProgress
StoresParentTemplateValues
HasNumberSubstitutionChanged
HasTemplateGeneratedSubTree
HasImplicitStyleFromResources
ShouldLookupImplicitStyles
IsStyleSetFromGenerator
HasStyleChanged
HasTemplateChanged
HasStyleInvalidated
HasStyleEverBeenFetched
HasLocalStyle
HasThemeStyleEverBeenFetched
AncestorChangeInProgress
InheritableProperties
LoadedPending
  • Type:Object[]
UnloadedPending
  • Type:Object[]
HasMultipleInheritanceContexts
PotentiallyHasMentees
InputBindingsInternal
CommandBindingsInternal
EventHandlersStore
  • Type:EventHandlersStore
StylusPlugIns
  • Type:StylusPlugInCollection
PreviousConstraint
  • Type:Size
HasEffectiveKeyboardFocus
IsEnabledCore
PreviousArrangeRect
  • Type:Rect
HasAutomationPeer
SnapsToDevicePixelsCache
ClipToBoundsCache
MeasureDirty
ArrangeDirty
MeasureInProgress
ArrangeInProgress
NeverMeasured
NeverArranged
MeasureDuringArrange
AreTransformsClean
IsVisualChildrenIterationInProgress
IsRootElement
VisualContentBounds
  • Type:Rect
VisualDescendantBounds
  • Type:Rect
InternalVisualChildrenCount
InternalVisual2DOr3DChildrenCount
HasVisualChildren
TreeLevel
  • Type:UInt32
VisualParent
InternalVisualParent
VisualTransform
  • Type:Transform
VisualEffect
  • Type:Effect
VisualEffectInternal
  • Type:Effect
VisualBitmapEffect
  • Type:BitmapEffect
VisualBitmapEffectInput
BitmapEffectEmulationDisabled
VisualBitmapEffectInternal
  • Type:BitmapEffect
VisualBitmapEffectInputInternal
VisualCacheMode
  • Type:CacheMode
VisualScrollableAreaClip
  • Type:Nullable<Rect>
VisualClip
  • Type:Geometry
VisualOffset
  • Type:Vector
VisualOpacity
VisualEdgeMode
  • Type:EdgeMode
VisualBitmapScalingMode
  • Type:BitmapScalingMode
VisualClearTypeHint
  • Type:ClearTypeHint
VisualTextRenderingMode
  • Type:TextRenderingMode
VisualTextHintingMode
  • Type:TextHintingMode
VisualOpacityMask
  • Type:Brush
VisualXSnappingGuidelines
  • Type:DoubleCollection
VisualYSnappingGuidelines
ClipChangedHandler
  • Type:EventHandler
ScrollableAreaClipChangedHandler
  • Type:EventHandler
TransformChangedHandler
  • Type:EventHandler
EffectChangedHandler
  • Type:EventHandler
CacheModeChangedHandler
  • Type:EventHandler
GuidelinesChangedHandler
  • Type:EventHandler
OpacityMaskChangedHandler
  • Type:EventHandler
ContentsChangedHandler
  • Type:EventHandler
IsInheritanceContextSealed
Freezable_Frozen
Freezable_HasMultipleInheritanceContexts
Freezable_UsingHandlerList
Freezable_UsingContextList
Freezable_UsingSingletonHandler
Freezable_UsingSingletonContext
Animatable_IsResourceInvalidationNecessary
IAnimatable_HasAnimatedProperties
CanBeInheritanceContext
EffectiveValues
  • Type:EffectiveValueEntry[]
EffectiveValuesCount
  • Type:UInt32
InheritableEffectiveValuesCount
  • Type:UInt32
InheritanceParent
GlobeButtonClick This event raises when clicking on the Globe button on the PanZoomBar.
Event Arguments:GlobeButtonClickPanZoomBarMapToolEventArgs
PreviewMouseDoubleClick N/A
Event Arguments:
Event Arguments:
TargetUpdated N/A
Event Arguments:DataTransferEventArgs
SourceUpdated N/A
DataContextChanged N/A
Event Arguments:
RequestBringIntoView N/A
Event Arguments:
SizeChanged N/A
Event Arguments:
Initialized N/A
Event Arguments:
Loaded N/A
Event Arguments:
Unloaded N/A
Event Arguments:
ToolTipOpening N/A
Event Arguments:
ToolTipClosing N/A
Event Arguments:
ContextMenuOpening N/A
Event Arguments:
ContextMenuClosing N/A
Event Arguments:
PreviewMouseDown N/A
Event Arguments:
MouseDown N/A
Event Arguments:
PreviewMouseUp N/A
Event Arguments:
MouseUp N/A
Event Arguments:
PreviewMouseLeftButtonDown N/A
Event Arguments:
Event Arguments:
PreviewMouseLeftButtonUp N/A
Event Arguments:
Event Arguments:
PreviewMouseRightButtonDown N/A
Event Arguments:
Event Arguments:
PreviewMouseRightButtonUp N/A
Event Arguments:
Event Arguments:
PreviewMouseMove N/A
Event Arguments:
MouseMove N/A
Event Arguments:
PreviewMouseWheel N/A
Event Arguments:
MouseWheel N/A
Event Arguments:
MouseEnter N/A
Event Arguments:
MouseLeave N/A
Event Arguments:
GotMouseCapture N/A
Event Arguments:
LostMouseCapture N/A
Event Arguments:
QueryCursor N/A
Event Arguments:
PreviewStylusDown N/A
Event Arguments:
StylusDown N/A
Event Arguments:
PreviewStylusUp N/A
Event Arguments:
StylusUp N/A
Event Arguments:
PreviewStylusMove N/A
Event Arguments:
StylusMove N/A
Event Arguments:
PreviewStylusInAirMove N/A
Event Arguments:
StylusInAirMove N/A
Event Arguments:
StylusEnter N/A
Event Arguments:
StylusLeave N/A
Event Arguments:
PreviewStylusInRange N/A
Event Arguments:
StylusInRange N/A
Event Arguments:
PreviewStylusOutOfRange N/A
Event Arguments:
Event Arguments:
PreviewStylusSystemGesture N/A
Event Arguments:
Event Arguments:
GotStylusCapture N/A
Event Arguments:
LostStylusCapture N/A
Event Arguments:
StylusButtonDown N/A
Event Arguments:
StylusButtonUp N/A
Event Arguments:
PreviewStylusButtonDown N/A
Event Arguments:
PreviewStylusButtonUp N/A
Event Arguments:
PreviewKeyDown N/A
Event Arguments:
KeyDown N/A
Event Arguments:
PreviewKeyUp N/A
Event Arguments:
KeyUp N/A
Event Arguments:
PreviewGotKeyboardFocus N/A
Event Arguments:
Event Arguments:
PreviewLostKeyboardFocus N/A
Event Arguments:
Event Arguments:
PreviewTextInput N/A
Event Arguments:
TextInput N/A
Event Arguments:
PreviewQueryContinueDrag N/A
Event Arguments:
Event Arguments:
PreviewGiveFeedback N/A
Event Arguments:
GiveFeedback N/A
Event Arguments:
PreviewDragEnter N/A
Event Arguments:
DragEnter N/A
Event Arguments:
PreviewDragOver N/A
Event Arguments:
DragOver N/A
Event Arguments:
PreviewDragLeave N/A
Event Arguments:
DragLeave N/A
Event Arguments:
PreviewDrop N/A
Event Arguments:
Drop N/A
Event Arguments:
PreviewTouchDown N/A
Event Arguments:TouchEventArgs
TouchDown N/A
PreviewTouchMove N/A
TouchMove N/A
PreviewTouchUp N/A
TouchUp N/A
GotTouchCapture N/A
LostTouchCapture N/A
TouchEnter N/A
TouchLeave N/A
IsMouseDirectlyOverChanged N/A
Event Arguments:
IsKeyboardFocusWithinChanged N/A
Event Arguments:
IsMouseCapturedChanged N/A
Event Arguments:
IsMouseCaptureWithinChanged N/A
Event Arguments:
IsStylusDirectlyOverChanged N/A
Event Arguments:
IsStylusCapturedChanged N/A
Event Arguments:
IsStylusCaptureWithinChanged N/A
Event Arguments:
IsKeyboardFocusedChanged N/A
Event Arguments:
LayoutUpdated N/A
Event Arguments:
GotFocus N/A
Event Arguments:
LostFocus N/A
Event Arguments:
IsEnabledChanged N/A
Event Arguments:
IsHitTestVisibleChanged N/A
Event Arguments:
IsVisibleChanged N/A
Event Arguments:
FocusableChanged N/A
Event Arguments:
ManipulationStarting N/A
Event Arguments:ManipulationStartingEventArgs
ManipulationStarted N/A
Event Arguments:ManipulationStartedEventArgs
ManipulationDelta N/A
Event Arguments:ManipulationDeltaEventArgs
ManipulationInertiaStarting N/A
Event Arguments:ManipulationInertiaStartingEventArgs
ManipulationBoundaryFeedback N/A
Event Arguments:ManipulationBoundaryFeedbackEventArgs
ManipulationCompleted N/A
Event Arguments:ManipulationCompletedEventArgs
thinkgeo.mapsuite.wpfdesktopedition.panzoombarmaptool.txt · Last modified: 2017/03/16 21:59 (external edit)
