thinkgeo.mapsuite.wpfdesktopedition.currentextentchangingwpfmapeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangingWpfMapEventArgs
Provides data for the CurrentExtentChanging event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangingWpfMapEventArgs
CurrentExtentChangingWpfMapEventArgs()
  • Initialize an instance of the CurrentExtentChangingEventArgs class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangingWpfMapEventArgs#CurrentExtentChangingWpfMapEventArgs.28.29
CurrentExtentChangingWpfMapEventArgs(RectangleShape,RectangleShape,GeographyUnit,Single,Single,Boolean)
  • Initialize an instance of the CurrentExtentChangingEventArgs class by passing the currentExtent, mapUnit, mapWidth and mapHeight.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangingWpfMapEventArgs#CurrentExtentChangingWpfMapEventArgs.28RectangleShape.2C_RectangleShape.2C_GeographyUnit.2C_Single.2C_Single.2C_Boolean.29
  • currentExtent
    • Description:A RectangleShape indicates current map extent.
  • newExtent
    • Description:A RecangleShape indicates the target extent for map.
  • mapUnit
    • Description:A GeographyUnit value indicates current map unit.
  • mapWidth
    • Type:Single
    • Description:A float value indicates screen width of current map.
  • mapHeight
    • Type:Single
    • Description:A float value indicates screen height of current map.
  • cancel
    • Description:A boolean value indicates whether current operation needs cancel.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangingWpfMapEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangingWpfMapEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangingWpfMapEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangingWpfMapEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangingWpfMapEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangingWpfMapEventArgs#MemberwiseClone.28.29
CurrentExtent
This property specifies the CurrentExtent of the CurrentExtentChangingEventArgs.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangingWpfMapEventArgs#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto
NewExtent
This property specifies the NewExtent of the CurrentExtentChangingEventArgs.
MapUnit
This property specifies the MapUnit of the CurrentExtentChangingEventArgs.
MapWidth
This property specifies the MapWidth of the CurrentExtentChangingEventArgs.
  • Type:Single
MapHeight
This property specifies the MapHeight of the CurrentExtentChangingEventArgs.
  • Type:Single
Cancel
Gets or sets whether the action will be canceled or not.
thinkgeo.mapsuite.wpfdesktopedition.currentextentchangingwpfmapeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
