thinkgeo.mapsuite.wpfdesktopedition.markerdraggingsimplemarkeroverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.MarkerDraggingSimpleMarkerOverlayEventArgs
This class represents the MarkerDragging event argument for SimpleMarkerOverlay.
      • ThinkGeo.MapSuite.WpfDesktopEdition.MarkerDraggingSimpleMarkerOverlayEventArgs
MarkerDraggingSimpleMarkerOverlayEventArgs()
  • Constructor of MarkerDraggingSimpleMarkerOverlayEventArgs class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MarkerDraggingSimpleMarkerOverlayEventArgs#MarkerDraggingSimpleMarkerOverlayEventArgs.28.29
MarkerDraggingSimpleMarkerOverlayEventArgs(Marker,PointShape,ScreenPointF)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MarkerDraggingSimpleMarkerOverlayEventArgs#MarkerDraggingSimpleMarkerOverlayEventArgs.28Marker.2C_PointShape.2C_ScreenPointF.29
  • draggingMarker
    • Type:Marker
    • Description:This parameter indicates the marker which is being dragged.
  • worldCoordinate
    • Description:This parameter indicates current mouse position in world coordinate.
  • screenCoordinate
    • Description:This parameter indicates current mouse position in screen coordinate.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MarkerDraggingSimpleMarkerOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MarkerDraggingSimpleMarkerOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MarkerDraggingSimpleMarkerOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MarkerDraggingSimpleMarkerOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MarkerDraggingSimpleMarkerOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MarkerDraggingSimpleMarkerOverlayEventArgs#MemberwiseClone.28.29
DraggingMarker
Gets or sets the marker which is being dragged.
WorldCoordinate
This proerpty gets and sets current mouse position in world coordinate.
ScreenCoordinate
Gets or sets current mouse position in screen coordinate.
thinkgeo.mapsuite.wpfdesktopedition.markerdraggingsimplemarkeroverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
