thinkgeo.mapsuite.wpfdesktopedition.currentscalechangingwpfmapeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs
Provides data for the CurrentScaleChanging event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs
CurrentScaleChangingWpfMapEventArgs()
  • Initialize an instance of the CurrentScaleChangingEventArgs class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#CurrentScaleChangingWpfMapEventArgs.28.29
CurrentScaleChangingWpfMapEventArgs(RectangleShape,Double,Double,GeographyUnit,Single,Single,Boolean)
  • Initialize an instance of the CurrentScaleChangingEventArgs class by passing the currentScale, mapUnit, mapWidth and mapHeight.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#CurrentScaleChangingWpfMapEventArgs.28RectangleShape.2C_Double.2C_Double.2C_GeographyUnit.2C_Single.2C_Single.2C_Boolean.29
  • currentExtent
    • Description:A RectangleShape indicates current map extent.
  • currentScale
    • Description:A double value indicates current map scale.
  • newScale
    • Description:A double value indicates the new scale needs to zoom to.
  • mapUnit
    • Description:A GeographyUnit indicates current map unit.
  • mapWidth
    • Type:Single
    • Description:A float value indicates current map scrren width.
  • mapHeight
    • Type:Single
    • Description:A float value indicates current map scrren height.
  • cancel
    • Description:A boolean value indicates whether needs to cancel current operation.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#MemberwiseClone.28.29
CurrentScale
This property specifies the CurrentScale of the CurrentScaleChangingEventArgs.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto
NewScale
This property specifies the NewScale of the CurrentScaleChangingEventArgs.
MapUnit
This property specifies the MapUnit of the CurrentScaleChangingEventArgs.
MapWidth
This property specifies the MapWidth of the CurrentScaleChangingEventArgs.
  • Type:Single
MapHeight
This property specifies the MapHeight of the CurrentExtentChangedEventArgs.
  • Type:Single
CurrentExtent
This property specifies the CurrentExtent of the CurrentExtentChangedEventArgs.
Cancel
Gets or sets whether the action will be canceled or not.
thinkgeo.mapsuite.wpfdesktopedition.currentscalechangingwpfmapeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
