thinkgeo.mapsuite.wpfdesktopedition.overlaydrawingwpfmapeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawingWpfMapEventArgs
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised before any of the overlays are drawn.
      • ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawingWpfMapEventArgs
OverlayDrawingWpfMapEventArgs()
Constructor of OverlayDrawingWpfMapEventArgs class.
OverlayDrawingWpfMapEventArgs(Overlay,RectangleShape,Boolean)
  • overlay
    • Type:Overlay
    • Description:This parameter is the overlay that will be drawn.
  • targetExtent
    • Description:This parameter is the canvas that will are drawing on.
  • cancel
    • Description:This parameter specifies whether or not we will cancel drawing of the overlay.
Overlay
Gets or sets the overlay you will be drawing.
Cancel
Gets or sets whether the action will be canceled or not.
TargetExtent
Gets or sets the extent for drawing this overlay.
thinkgeo.mapsuite.wpfdesktopedition.overlaydrawingwpfmapeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
