thinkgeo.mapsuite.wpfdesktopedition.overlay
ThinkGeo.MapSuite.WpfDesktopEdition.Overlay
This class is the base class of all overlays in this overlay system.
Overlay()
Constructor of the Overlay class.
Refresh(IEnumerable<RectangleShape>)
Refresh(TimeSpan)
  • bufferTime
    • Type:TimeSpan
Refresh(TimeSpan,RequestDrawingBufferTimeType)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
Initialize(MapArguments)
This method initializes overlay object.
This is a wrapper method for the virtual method InitializeCore.
  • mapArguments
    • Description:This parameter maintains current map information for calculating mechanism.
Refresh(RectangleShape)
Refresh()
This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles.
Close()
Open()
Draw(RectangleShape)
This method draws the overlay with the provided extent in world coordinate.
  • targetExtent
    • Description:This parameter indicates an extent in world coordinate for drawing the overlay.
Draw(RectangleShape,OverlayRefreshType)
  • targetExtent
  • refreshType
    • Description:This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning the map around, the existing tile doesn't need to be redraw, the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode.
PanTo(RectangleShape)
This method pans the overlay to the provided world extent.
Some overlay doesn't need to continously drawing all the tile. For example, MarkerOverlay is formed by markers. When mouse down to pan, the markers don't need to redraw, we can only change its position. When mouse up to end panning, we can redraw the overlay for better performance.
  • targetExtent
    • Description:This parameter is the target world extent for panning.
GetBoundingBox()
This method gets a bounding box of the Overlay.
This method is the concrete wrapper for the abstract method GetBoundingBoxCore. This method returns the bounding box of the Overlay. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Description:A RectangleShape indicating the bounding box of this overlay
SaveState()
This method saves overlay state to a byte array.
  • Type:Byte[]
  • Description:A byte array indicates current overlay state.
LoadState(Byte[])
This method restore the overlay state back from the specified state.
  • state
    • Type:Byte[]
    • Description:This parameter indicates the state for restore the overlay.
Dispose()
This method dispose unmanaged resource used in this class.
InitializeCore(MapArguments)
When implementing this method, consider initializing the overlay canvas such as setting its z-index, setting current map reference to the CurrentMap property.
  • mapArguments
RefreshCore(RectangleShape)
RefreshCore()
CloseCore()
OpenCore()
DrawCore(RectangleShape,OverlayRefreshType)
  • targetExtent
  • overlayRefreshType
    • Description:This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning or zooming the map, the existing tile doesn't need to be redraw, because the styles are the same as the previous states. the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode.
4hM=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
PanToCore(RectangleShape)
  • targetExtent
OnDrawing(DrawingOverlayEventArgs)
This method raises before the overlay is drawing.
OnDrawn(DrawnOverlayEventArgs)
This method raises after the overlay is drawn.
GetBoundingBoxCore()
  • Description:This method returns the bounding box of the Overlay.
SaveStateCore()
  • Type:Byte[]
LoadStateCore(Byte[])
  • state
    • Type:Byte[]
Finalizer of this Overlay object.
Dispose(Boolean)
  • disposing
OnRefreshing(OverlayRefreshType)
AutoRefreshInterval
  • Type:TimeSpan
Gets or sets the name of this overaly.
MapArguments
Gets or sets current map information which will be used for calculating mechanism.
OverlayCanvas
Gets or sets the actual canvas which maintains all the visual elements on the overlay.
  • Type:Canvas
IsBase
CanRefreshRegion
DrawingExceptionMode
This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
IsVisible
Gets or sets if this overlay is visible.
Attribution
IsEmpty
This property gets if this overlay is empty or not.
This property enhances the performance of the overlay while drawing. If is true, we will skip drawing this overlay and continue drawing the next overlay.
PreviousExtent
Gets or sets the previous exent of the overlay.
3BM=
IsOverlayInitialized
Gets or sets if the overlay canvas is initialized.
Drawing This event raises before the overlay is drawing.
Event Arguments:DrawingOverlayEventArgs
Drawn This event raises after the overlay is drawn.
Event Arguments:DrawnOverlayEventArgs
DrawingAttribution N/A
Event Arguments:DrawingAttributionOverlayEventArgs
DrawnAttribution N/A
Event Arguments:DrawnAttributionOverlayEventArgs
thinkgeo.mapsuite.wpfdesktopedition.overlay.txt · Last modified: 2017/03/16 21:59 (external edit)
