thinkgeo.mapsuite.wpfdesktopedition.mapdoublerightclickmode
ThinkGeo.MapSuite.WpfDesktopEdition.MapDoubleRightClickMode
This enumeration specifies the behavior that occurs when double-right-clicking on the MapControl. The default value is ZoomOut.
Items
Default
  • Summary:Default value (ZoomOut) of the enumeration.
ZoomOut
  • Summary:This enumeration item means that the map will ZoomOut when a double-right-click occurs.
Disabled
  • Summary:This enumeration item means that the ZoomOut functionality for double-right-clicks will be disabled.
thinkgeo.mapsuite.wpfdesktopedition.mapdoublerightclickmode.txt · Last modified: 2017/03/16 21:59 (external edit)
