thinkgeo.mapsuite.wpfdesktopedition.mousecoordinatetype
ThinkGeo.MapSuite.WpfDesktopEdition.MouseCoordinateType
This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
Map.MousePosition.MousePostionType property uses this enumeration to determine which position type to appears when the pointer is moving around the map.
Items
Default
  • Summary:Default mouse position type, format: “longitude, latitude”.
LongitudeLatitude
LatitudeLongitude
  • Summary:Default mouse position type, format: “latitude, longitude”.
DegreesMinutesSeconds
  • Summary:Appear degrees, minutes, seconds, format: “Degressº Minutes'' Seconds'”.
Custom
  • Summary:Customize format of mouse coordinates.
thinkgeo.mapsuite.wpfdesktopedition.mousecoordinatetype.txt · Last modified: 2017/03/16 21:59 (external edit)
