thinkgeo.mapsuite.wpfdesktopedition.trackstartedtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs
Provides data for the TrackStarted. event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs
TrackStartedTrackInteractiveOverlayEventArgs()
  • Constructor of TrackStartedTrackInteractiveOverlayEventArgs class.
TrackStartedTrackInteractiveOverlayEventArgs(Vertex)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs#TrackStartedTrackInteractiveOverlayEventArgs.28Vertex.29
  • startedVertex
    • Type:Vertex
    • Description:This parameter specified the started vertex when tracking shape action is started.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs#MemberwiseClone.28.29
StartedVertex
Gets or sets the started vertex when tracking shape action is started.
thinkgeo.mapsuite.wpfdesktopedition.trackstartedtrackinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
