thinkgeo.mapsuite.wpfdesktopedition.maptools
ThinkGeo.MapSuite.WpfDesktopEdition.MapTools
Contains the different map tools as properties and acts as an entrance for setting these map controls.
MapTools()
  • Constructor of MapTools class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MapTools.28.29
MapTools(WpfMap)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MapTools.28WpfMap.29
  • wpfMap
    • Type:WpfMap
    • Description:A WpfMap object that all map tools in this object is based on.
Refresh()
  • Refreshes all the map tools objects maintaining in the MapTools object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#Refresh.28.29
GetKeys()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#GetKeys.28.29
  • Type:Collection<String>
Add(String,MapTool)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#Add.28String.2C_MapTool.29
  • key
  • item
Add(MapTool)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#Add.28MapTool.29
  • item
Insert(Int32,MapTool)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#Insert.28Int32.2C_MapTool.29
  • index
  • item
Insert(Int32,String,MapTool)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#Insert.28Int32.2C_String.2C_MapTool.29
  • index
  • key
  • item
Remove(String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#Remove.28String.29
  • key
MoveUp(Int32)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveUp.28Int32.29
  • index
MoveUp(String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveUp.28String.29
  • key
MoveUp(MapTool)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveUp.28MapTool.29
  • item
MoveDown(Int32)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveDown.28Int32.29
  • index
MoveDown(String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveDown.28String.29
  • key
MoveDown(MapTool)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveDown.28MapTool.29
  • item
MoveToTop(Int32)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveToTop.28Int32.29
  • index
MoveToTop(String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveToTop.28String.29
  • key
MoveToTop(MapTool)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveToTop.28MapTool.29
  • item
MoveToBottom(Int32)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveToBottom.28Int32.29
  • index
MoveToBottom(String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveToBottom.28String.29
  • key
MoveToBottom(MapTool)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveToBottom.28MapTool.29
  • item
MoveTo(Int32,Int32)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveTo.28Int32.2C_Int32.29
  • fromIndex
  • toIndex
MoveTo(String,Int32)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveTo.28String.2C_Int32.29
  • key
  • toIndex
MoveTo(MapTool,Int32)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MoveTo.28MapTool.2C_Int32.29
  • item
  • toIndex
Contains(String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#Contains.28String.29
  • key
Add(MapTool)
  • item
Clear()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#Clear.28.29
CopyTo(MapTool[],Int32)
  • index
Contains(MapTool)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#Contains.28MapTool.29
  • item
GetEnumerator()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#GetEnumerator.28.29
  • Type:IEnumerator<MapTool>
IndexOf(MapTool)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#IndexOf.28MapTool.29
  • item
  • index
  • item
Remove(MapTool)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#Remove.28MapTool.29
  • item
RemoveAt(Int32)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#RemoveAt.28Int32.29
  • index
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#GetType.28.29
OnInserting(InsertingGeoCollectionEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#OnInserting.28InsertingGeoCollectionEventArgs.29
OnInserted(InsertedGeoCollectionEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#OnInserted.28InsertedGeoCollectionEventArgs.29
OnRemoving(RemovingGeoCollectionEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#OnRemoving.28RemovingGeoCollectionEventArgs.29
OnRemoved(RemovedGeoCollectionEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#OnRemoved.28RemovedGeoCollectionEventArgs.29
OnAdding(AddingGeoCollectionEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#OnAdding.28AddingGeoCollectionEventArgs.29
OnAdded(AddedGeoCollectionEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#OnAdded.28AddedGeoCollectionEventArgs.29
OnClearingItems(ClearingItemsGeoCollectionEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#OnClearingItems.28ClearingItemsGeoCollectionEventArgs.29
OnClearedItems(ClearedItemsGeoCollectionEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#OnClearedItems.28ClearedItemsGeoCollectionEventArgs.29
InsertItem(Int32,MapTool)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#InsertItem.28Int32.2C_MapTool.29
  • index
  • item
RemoveItem(Int32)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#RemoveItem.28Int32.29
  • index
ClearItems()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#ClearItems.28.29
SetItem(Int32,MapTool)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#SetItem.28Int32.2C_MapTool.29
  • index
  • item
OnCollectionChanged(NotifyCollectionChangedEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#OnCollectionChanged.28NotifyCollectionChangedEventArgs.29
  • e
    • Type:NotifyCollectionChangedEventArgs
OnPropertyChanged(PropertyChangedEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#OnPropertyChanged.28PropertyChangedEventArgs.29
  • e
    • Type:PropertyChangedEventArgs
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MemberwiseClone.28.29
Logo
Gets a shortcut of LogoMapTool object.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#Logo
MouseCoordinate
Gets a shortcut of MouseCoordinate object.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#MouseCoordinate
PanZoomBar
Gets a shortcut of PanZoomBar object.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#PanZoomBar
ScaleLine
Gets a shortcut of ScaleLine object.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#ScaleLine
Item
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#ClearItems.28.29
Count
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#Count
Item
Items
Inserting N/A
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#OnAdded.28AddedGeoCollectionEventArgs.29
Event Arguments:AddedGeoCollectionEventArgs
ClearingItems N/A
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#OnCollectionChanged.28NotifyCollectionChangedEventArgs.29
Event Arguments:
PropertyChanged N/A
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapTools#OnPropertyChanged.28PropertyChangedEventArgs.29
Event Arguments:
thinkgeo.mapsuite.wpfdesktopedition.maptools.txt · Last modified: 2017/03/16 21:59 (external edit)
