thinkgeo.mapsuite.wpfdesktopedition.currentextentchangedwpfmapeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs
Provides data for the CurrentExtentChanged event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs
CurrentExtentChangedWpfMapEventArgs()
  • Initialize an instance of the CurrentExtentChangedEventArgs class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#CurrentExtentChangedWpfMapEventArgs.28.29
CurrentExtentChangedWpfMapEventArgs(RectangleShape,GeographyUnit,Single,Single)
  • Initialize an instance of the CurrentExtentChangedEventArgs class by passing the currentExtent, mapUnit, mapWidth and mapHeight.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#CurrentExtentChangedWpfMapEventArgs.28RectangleShape.2C_GeographyUnit.2C_Single.2C_Single.29
  • currentExtent
    • Description:A RectangleShape indicates current map extent.
  • mapUnit
    • Description:A GeographyUnit indicates current map unit.
  • mapWidth
    • Type:Single
    • Description:A float value indicates the screen with of current map.
  • mapHeight
    • Type:Single
    • Description:A float value indicates the screen height of current map.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#MemberwiseClone.28.29
CurrentExtent
This property specifies the CurrentExtent of the CurrentExtentChangedEventArgs.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto
MapUnit
This property specifies the MapUnit of the CurrentExtentChangedEventArgs.
MapWidth
This property specifies the MapWidth of the CurrentExtentChangedEventArgs.
  • Type:Single
MapHeight
This property specifies the MapHeight of the CurrentExtentChangedEventArgs.
  • Type:Single
thinkgeo.mapsuite.wpfdesktopedition.currentextentchangedwpfmapeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
