thinkgeo.mapsuite.wpfdesktopedition.vertexaddedtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddedTrackInteractiveOverlayEventArgs
Provides data for the VertexAdded. event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddedTrackInteractiveOverlayEventArgs
VertexAddedTrackInteractiveOverlayEventArgs()
  • Constructor of VertexAddedTrackInteractiveOverlayEventArgs class.
VertexAddedTrackInteractiveOverlayEventArgs(Vertex,Feature)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddedTrackInteractiveOverlayEventArgs#VertexAddedTrackInteractiveOverlayEventArgs.28Vertex.2C_Feature.29
  • addedVertex
    • Type:Vertex
    • Description:This parameter specified the vertex is added.
  • affectedFeature
    • Type:Feature
    • Description:This parameter specified the feature to be used to add vertex on when tracking shape.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddedTrackInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddedTrackInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddedTrackInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddedTrackInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddedTrackInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexAddedTrackInteractiveOverlayEventArgs#MemberwiseClone.28.29
AddedVertex
Gets or sets the vertex added.
AffectedFeature
Gets or sets the Feature with vertex added.
thinkgeo.mapsuite.wpfdesktopedition.vertexaddedtrackinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
