This class represents a group of layers; each layer can be of any layer type.
  Draw(RectangleShape,OverlayRefreshType)
  DrawCore(RectangleShape,OverlayRefreshType)
  OnTileTypeChanged(TileTypeChangedTileOverlayEventArgs)
  OnDrawTilesProgressChanged(DrawTilesProgressChangedTileOverlayEventArgs)
  OnDrawingTile(DrawingTileTileOverlayEventArgs)
  OnDrawnTile(DrawnTileTileOverlayEventArgs)
  GetDrawingCells(RectangleShape)
  GetDrawingCellsCore(RectangleShape)
  GetTileMatrix(Double,Int32,Int32,GeographyUnit)
  OnDrawingException(DrawingExceptionTileOverlayEventArgs)
  IxQ=(RectangleShape,Double,Double,Int64,Int64,Int32)
  DrawStretchTiles(RectangleShape)
  GetSortedCells(Dictionary<String,TileMatrixCell>,RectangleShape)
  GetSortedCellsCore(Dictionary<String,TileMatrixCell>,RectangleShape)
  4BM=(IEnumerable<RectangleShape>)
  OnDrawing(DrawingOverlayEventArgs)
  OnDrawn(DrawnOverlayEventArgs)
Set GdiPlus to render map image with Gdi+. We recommend use this value with large data. Set DrawingVisual to render map image with DrawingVisual feature in WPF. Use it when the spatial data is small to get better responding.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#IsEmpty
The <strong>Layers</strong> property holds all of the layers that are used by the <strong>Draw</strong> method. The Draw method loops through all layers to filter out features and draw on the image with the specified styles.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#DrawingQuality
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#LockLayerMode
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#IsVisible
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#TileType
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#TileWidth
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#TileHeight
Gets and sets the transition effect of the overlay when zooming. After zooming, the existing tiles stretch and leave in current viewport. Set to None when its background is transparent.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#TransitionEffect
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#TileCache
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#ImageFormat
Gets or sets the image quality when the TileImageFormat is Jpeg; otherwise this property has no effects. Its default value is 80.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#JpegQuality
This property gets and sets the number of extra rows and colums of tiles on each side which will surround the minimum grid tiles to cover the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#TileBuffer
By default, MaxExtent is null; the matrix is created depending on the GeographyUnit of current map. When it's DecimalDegree, the matrix' is calculated as (-180, 90, 180, -90) as MaxExtent. While it's not DecimalDegree, the matrix is (-1000000000, 1000000000, 1000000000, -1000000000); It's allowed to modify it to customize the matrix.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#WrappingMode
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#WrappingExtent
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#AutoRefreshInterval
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#Name
Gets or sets current map information which will be used for calculating mechanism.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#Initialize.28MapArguments.29
Gets or sets the actual canvas which maintains all the visual elements on the overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#OverlayCanvas
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#IsBase
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#CanRefreshRegion
This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#DrawingExceptionMode
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#DrawAttributionCore.28GeoCanvas.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#DrawingCanvas
Gets current stretch canvas which holds stretched tile controls during the stretch transition.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#StretchCanvas
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#PreviousExtent
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#IsOverlayInitialized
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#OnDrawTilesProgressChanged.28DrawTilesProgressChangedTileOverlayEventArgs.29
Event Arguments:DrawTilesProgressChangedTileOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#OnDrawingTile.28DrawingTileTileOverlayEventArgs.29
Event Arguments:DrawingTileTileOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#OnDrawnTile.28DrawnTileTileOverlayEventArgs.29
Event Arguments:DrawnTileTileOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#OnDrawingException.28DrawingExceptionTileOverlayEventArgs.29
Event Arguments:DrawingExceptionTileOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#OnDrawnException.28DrawnExceptionTileOverlayEventArgs.29
Event Arguments:DrawnExceptionTileOverlayEventArgs
Event Arguments:TileTypeChangedTileOverlayEventArgs
Event Arguments:StartingThreadTileOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#GetDrawingCells.28RectangleShape.29
Event Arguments:DrawingOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#OnDrawn.28DrawnOverlayEventArgs.29
Event Arguments:DrawnOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29
Event Arguments:DrawingAttributionOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29
Event Arguments:DrawnAttributionOverlayEventArgs
