This class represents an WmsOverlay which has MapSuite world map kit server integrated.
WorldMapKitWmsWpfOverlay(WebProxy)
WorldMapKitWmsWpfOverlay(WorldMapKitLayerType,WebProxy)
WorldMapKitWmsWpfOverlay(String,String)
WorldMapKitWmsWpfOverlay(WorldMapKitLayerType,String,String)
WorldMapKitWmsWpfOverlay(WebProxy,String,String)
WorldMapKitWmsWpfOverlay(WorldMapKitLayerType,WebProxy,String,String)
Draw(RectangleShape,OverlayRefreshType)
DrawTileCore(Tile,RectangleShape)
PrefillDataToTiles(IEnumerable<Tile>)
OnDrawTilesProgressChanged(DrawTilesProgressChangedTileOverlayEventArgs)
OnDrawingTile(DrawingTileTileOverlayEventArgs)
OnDrawnTile(DrawnTileTileOverlayEventArgs)
GetDrawingCells(RectangleShape)
GetDrawingCellsCore(RectangleShape)
GetTileMatrix(Double,Int32,Int32,GeographyUnit)
OnDrawingException(DrawingExceptionTileOverlayEventArgs)
IxQ=(RectangleShape,Double,Double,Int64,Int64,Int32)
DrawStretchTiles(RectangleShape)
GetSortedCells(Dictionary<String,TileMatrixCell>,RectangleShape)
GetSortedCellsCore(Dictionary<String,TileMatrixCell>,RectangleShape)
4BM=(IEnumerable<RectangleShape>)
OnDrawing(DrawingOverlayEventArgs)
OnDrawn(DrawnOverlayEventArgs)
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#WorldMapKitWmsWpfOverlay.28WorldMapKitLayerType.29
This property needs work with map unit setting on the map object. All overlay adding to the map must keep the same unit or else the map won't display properly.
Gets or sets the length of time, in seconds, before the request times out.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#TimeoutInSeconds
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#ClientId
Gets or sets a value that is unique to your client ID, please keep your key secure.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#PrivateKey
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#WorldMapKitWmsWpfOverlay.28WebProxy.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#IsVisible
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#TileType
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#TileWidth
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#TileHeight
Gets and sets the transition effect of the overlay when zooming. After zooming, the existing tiles stretch and leave in current viewport. Set to None when its background is transparent.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#TransitionEffect
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#TileCache
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#ImageFormat
Gets or sets the image quality when the TileImageFormat is Jpeg; otherwise this property has no effects. Its default value is 80.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#JpegQuality
This property gets and sets the number of extra rows and colums of tiles on each side which will surround the minimum grid tiles to cover the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#TileBuffer
By default, MaxExtent is null; the matrix is created depending on the GeographyUnit of current map. When it's DecimalDegree, the matrix' is calculated as (-180, 90, 180, -90) as MaxExtent. While it's not DecimalDegree, the matrix is (-1000000000, 1000000000, 1000000000, -1000000000); It's allowed to modify it to customize the matrix.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#WrappingMode
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#WrappingExtent
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#AutoRefreshInterval
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#Name
Gets or sets current map information which will be used for calculating mechanism.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#Initialize.28MapArguments.29
Gets or sets the actual canvas which maintains all the visual elements on the overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#OverlayCanvas
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#IsBase
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#CanRefreshRegion
This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#DrawingExceptionMode
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#DrawAttributionCore.28GeoCanvas.29
This property enhances the performance of the overlay while drawing. If is true, we will skip drawing this overlay and continue drawing the next overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#DrawingCanvas
Gets current stretch canvas which holds stretched tile controls during the stretch transition.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#StretchCanvas
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#PreviousExtent
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#IsOverlayInitialized
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#OnSendingWebRequest.28SendingWebRequestEventArgs.29
Event Arguments:SendingWebRequestEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#OnSentWebRequest.28SentWebRequestEventArgs.29
Event Arguments:SentWebRequestEventArgs
This event raises when download progress is changed.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#OnDrawTilesProgressChanged.28DrawTilesProgressChangedTileOverlayEventArgs.29
Event Arguments:DrawTilesProgressChangedTileOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#OnDrawingTile.28DrawingTileTileOverlayEventArgs.29
Event Arguments:DrawingTileTileOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#OnDrawnTile.28DrawnTileTileOverlayEventArgs.29
Event Arguments:DrawnTileTileOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#OnDrawingException.28DrawingExceptionTileOverlayEventArgs.29
Event Arguments:DrawingExceptionTileOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#OnDrawnException.28DrawnExceptionTileOverlayEventArgs.29
Event Arguments:DrawnExceptionTileOverlayEventArgs
Event Arguments:TileTypeChangedTileOverlayEventArgs
Event Arguments:StartingThreadTileOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#GetDrawingCells.28RectangleShape.29
Event Arguments:DrawingOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#OnDrawn.28DrawnOverlayEventArgs.29
Event Arguments:DrawnOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29
Event Arguments:DrawingAttributionOverlayEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.WorldMapKitWmsWpfOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29
Event Arguments:DrawnAttributionOverlayEventArgs
