thinkgeo.mapsuite.wpfdesktopedition.mapmousewheelmode
ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseWheelMode
This enumeration specifies the behavior that occurs when the mouse wheel is scrolled. The default value is Zooming.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseWheelMode
Items
Default
  • Summary:Default value (Zooming) of the enumeration.
Zooming
  • Summary:This enumeration item means that the map will ZoomIn or ZoomOut when the mouse wheel is scrolled up or down, respectively.
Disabled
  • Summary:This enumeration item means that the mouse wheel will be disabled and will have no effect on the MapControl.
thinkgeo.mapsuite.wpfdesktopedition.mapmousewheelmode.txt · Last modified: 2017/03/16 21:59 (external edit)
