map_suite_web_for_mvc_features_bug_fixes_change_log
Map Suite Web For MVC Edition Features & Bug Fixes Change Log
Version 10.6.0
Release date: 11/28/2019
ThinkGeo.MapSuite.Mvc Namespace:
  • Fixed a bug that OverlayType of AdornmentOverlay can't be found.
ThinkGeo.MapSuite Namespace:
  • Enhanced to support reprojection for Wmts.
  • Enhanced to support high resolution screen for ThinkGeoCloudRasterMapsLayer.
  • Enhanced to support high resolution screen for GoogleMapsLayer.
  • Fixed a bug that GoogleMapsLayer renders incorrect tiles when map extent is out of max extent of Google.
  • Fixed a bug that WmtsLayer can't serialize.
  • Fixed a bug that the projection don't works when FeatureSource is editing and IsTransactionLive of ShapeFileFeatureLayer is true.
  • Fixed a bug that Fdo doesn't work on the x64 target platform.
  • Fixed a bug that FikeGeoDatabase doesn't work on the x64 target platform.
  • Changed DrawingPointStyleEventArgs to DrawingDirectionPointEventArgs.
  • Added DirectionPointStyle property for LineStyline.
  • Enhanced to support ZoomLevel20 for ThinkGeoCloudMapsZoomLevelSet.
  • Improved render performance for OpenStreetMap.
  • Fixed a bug that the PDF and the Printer get different result with the Map if polygon contains inner rings.
  • Enhanced to support GeoLinearGradientBrush for Printer.
  • Enhanced to support GeoLinearGradientBrush in PDF.
  • Fixed a bug that the Direction convert to incorrect Angle in GeoLinearGradientBrush.
  • Fixed a bug. When parsing tile format tiff image, throws “Array index is out of range” exception.
  • Fixed a bug that cache expired don't works again because we need compare the UTC dateTime.
  • Enhanced to support rotation text for Cad.
  • Fixed a bug that raster layer is unmatched with vector layer when printing.
  • Fixed a bug that the projection '90091' srid can't be found from Esri projectin list.
  • Fixed a bug that GeoTiff will jump when reprojection.
  • Improved S57 index building performance.
  • Fixed a bug. When Setting the IsActive of specified zoomlevel to false, map still draw the shape follow the style of other zoomlevel.
  • Fixed a bug that QueryTool doesn't work.
  • Fixed a bug that the label is rendered at incorrect position under different DPI.
  • Improved render performance for NauticalChartsFeatureLayer.
  • Fixed a bug that RotationAngle of PointStyle doesn't work when printing map.
  • Fixed a bug resouce files of LegendAdornmentLayer can't be found.
  • Fixed a bug that zooming to deeper than level 20 OpenStreetMapsLayer throws a exception.
Version 10.5.0
Release date: 04/01/2019
  • Enhanced to rename ThinkGeoCloudMapsOverlay to ThinkGeoCloudRasterMapsOverlay and ThinkGeoCloudMapsMapType to ThinkGeoCloudRasterMapsMapType
  • Enhanced to support ThinkGeoCloudMapsOverlay in script
  • Fixed a bug that default ThinkGeo Cloud Maps server URLs need get updated
  • Fixed a bug that default projection of XYZ layer is incorrect, now it's “EPSG:900913”
  • Added support of Skia as the drawing engine to improve the performance.
  • Added support of semantic cartography schema – StyleJSON to design the map.
  • Added support of vector tile based *.MbTiles format.
  • Added support of ThinkGeoCloudRasterMapsLayer
  • Added support of high resolution for PlatformGeoCanvas, it mainly works for iOS edition
  • Enhanced to support parse special node in capability XML contains two spaces for WMTSLayer, generally Oracle export this type XML
  • Enhanced to support “ScaleFactor” property, it shows the high resolution value, it mainly works for iOS edition
  • Enhanced to support drawing halo pen dasharray on SkiaGeoCanvas
  • Enhanced to support both meter and decimal degree for NauticalCharts
  • Enhanced to support use ThinkGeoCloudRasterMapsLayer in iOS and Android edition
  • Fixed a bug that print google map to pdf tile unmatch
  • Fixed a bug that BuildingAreaStyle don't works follow design
  • Fixed a bug that OSM Buildings Url need get updated
  • Fixed a bug that some geotiff files looks jump when pan on map after set projection
  • Fixed a bug that text style don't works for wrapping lines in certain scenario
  • Fixed a bug that wrong boundary limit for Proj4Projection in certain scenario
  • Fixed a bug that the width or height value maybe equal zero when calling ToScreenCoordinate for GeoTiff
  • Fixed a bug that projection cannot handle parameter correct in certain scenario
  • Fixed a bug that PlatformGeocanvas throw format exception in certain scenario
  • Fixed a bug that GetDrawingExtent function loss precision in certain scenario
  • Fixed a bug that MapType is invalid when initializing ThinkGeoCloudRasterMapsLayer
  • Fixed bugs that some geotiff files cannot load correct
Version 10.4.0
Release date: 12/10/2018
  • Added new class ThinkGeoCloudMapsOverlay to support new ThinkGeo Cloud Map
  • Enhanced to use more accurate exception information
  • Fixed an bug failed to load Microsoft.SqlServer.Types assembly in certain scenario
  • Added new overloading method for DrawText in GeoCanvas class
  • Enhanced to get better performance for data drawing when shape file contains many inner rings in polygon
  • Enhanced to support Esri srid input for Proj4Projection
  • Enhanced to support Esri coordinate system when create table for FileGeoDatabase
  • Enhanced to use more accurate exception information and exception type
  • Fixed a bug map throw null reference exception in certain scenario
  • Fixed a bug the Sqlite R Tree calculate different result in Windows and Linux
  • Fixed a bug some special invalid saturation and luminance values for GeoColor can pass our validation
  • Fixed a bug vector data won't render all shapes if the width is too big
  • Fixed a bug XyzFileBitmapTileCache lose cache ID in certain scenario
  • Fixed a bug GettingTileCache event won't be fired in correct step
  • Fixed a bug the overlays don't match when print to PDF
  • Fixed a bug white line shows for WMTSlayer
  • Fixed a bug exception is thrown when met invalid tile in WMTSlayer
  • Fixed a bug failed to load dll in FileGeoDatabase for asp.net scenario
  • Fixed a bug ECW render distorted image in special zoomlevel
  • Fixed a bug GeoTiff image jump in certain scenario
Version 10.3.0
Release date: 7/26/2018
Version 10.2.0
Release date: 10/27/2017
Version 10.1.0
Release date: 06/21/2017
Version 10.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • Fixed a bug when highlighting the selected feature.
  • Fixed a bug that the popup close button is unable to click if AdornmentOverlay is added.
  • Fixed an exception when moving a DraggableMarker.
  • Fixed a bug that sets projection for ArcGISServerRestOverlay.
  • Fixed a bug that visible of marker is in inoperative.
  • Reduced the markers' size when there is no rotation.
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
ThinkGeo.MapSuite.MvcEdition Namespace:
  • Fixed a bug where the backgroud color is missed when calling PrintMap() method.
  • Fixed a bug where it's unable to zoom in/out with IE8 if an AdormentOverlay is added to the map.
  • Fixed a bug where some configurations of HighlightOverlay on server side is not passed to client side.
  • Fixed a bug where it's unable to disable the Google or any other third part JavaScript libraries.
  • Created a single JS file “thinkgeo.mvc.min.js” for client JavaScript library to improve loading performance.
  • Changed loading strategy of SimpleMarkerOverlay and Popups from once initialization to dynamically request.
  • Added support of ModelBinding on map control.
  • Changed the strategy of popups loading from first load initialization to ajax loading.
  • Added Leader Lines.
Version 8.0.0.160
Release date: 11/17/2014
  • Fixed a bug where some properties are not configured correctly on client side for HightlightOverlay.
  • Fixed a bug where the property of “IsDefaultJavascriptLibraryDisabled” doesn't take effect.
  • Fixed a bug where it's unable to zoom In/Out in IE8 if adornment layer is added.
Version 8.0.0.0
Release date: 06/06/2014
  • Fixed a bug where it's unable to create markeroverlay in controller.
  • Added supported to hide the default Markeroverlay in OverlaySwitcher.
  • Fixed a bug where the db connection is never closed in oraclefeaturelayer.
  • Fixed a bug where the attribution control covers the other elements in map.
  • Upgraded the Openlayers used in MvcEdition from 2.11 to 2.13.1.
  • Fixed a bug where client function Map1.getMarkerOverlay returns null.
  • Fixed a bug where NTS doe
map_suite_web_for_mvc_features_bug_fixes_change_log.txt · Last modified: 2019/12/06 01:52 by tgwikiupdate
